Author Topic: Vintage Hi-Fi speakers with crossovers? (how to test?)  (Read 16125 times)
Offline SoundTech-LG
Re: Vintage Hi-Fi speakers with crossovers? (how to test?)
« Reply #25 on: August 20, 2015, 08:04:42 pm »
Apparently I should hope someone knows the difference between 3rd order, and 3 way crossover. Not sure why that would even come up. You can look at the 2 way designs and see nothing but inductors in series, and capacitors in parallel with woofers as well. The series capacitor is a very unique design, and difficult to find. Nothing more, nothing less. No argument, even if you want it.
Offline Mark Hennessy
    • My electronics and audio website
« Reply #26 on: August 20, 2015, 08:27:53 pm »
That came up because I was wondering why your google image search for "3 way crossover design" would fit with:
Spent a few minutes trying to find at least ONE other Xover Ckt. that uses SERIES capacitors. Nope.
See if you can find something besides KEF...
https://www.google.com/search?q=3+way+crossover+design&biw=1280&bih=842&tbm=isch&tbo=u&source=univ&sa=X&ved=0CB0QsARqFQoTCOiwr5aIuMcCFU02iAodPMIF2g#imgrc=_         :-//
Not least because 3rd-order bass loading is generally reserved for small 2-way systems.
So naturally, I assumed you meant to search for "3rd-order bass tuning" or some variant thereof - that's the only way your words quoted above made sense in the context of the conversation. So not criticism; just clarification - mostly for the benefit of others who might be reading (it is a public forum after all).
Mark
« Reply #27 on: August 21, 2015, 02:01:04 am »
Assumptions never quite work out. :palm: I wasn't looking for anything more than Woofer SERIES capacitors in ANY crossover design,  2 way, 3 way, or even 4 way etc. If I'd searched on 3rd order designs, that might have been ALL I pulled up. In GENERAL most LF Xovers do not use series capacitors. That was the assumption I was using. These series caps are the exception, not the rule. :=\
