Its been a while, between being busy, getting covid etc, I have finally solved the problem. I went and replaced the four 2sc458s on the tone amp, however this turned out to be premature. doing voltage measurements, I found that two of the four were not biased on the base. surprisingly the culprit was two 220K resistors that were open circuit, I have never seen resistors go open on their own. weirdly they were small grey dipped resistors, the style that sort of look like a dog bone, and were unique to this board only. the last small annoying fault I'm chasing is the stereo lamp is not functioning. if i tune into a string station is does not illuminate. it is the MPX board that is responsible for this, I will post a screenshot of the part of schematic. There are three transistors that appear to be cascaded, Q7 is off, so Q8 is on, thus Q9 is off and the lamp is out. This doesn't change if I tune in or out of a station, and Im not great with these circuits to tell where the "control" signal is coming from. sorry for the essay, but if anyone has any input I would be grateful, Thanks.
Arthur
