Intro :Hi guys, how you all doing ?
I have been gifted my first ever oscilloscope, 2 channel - 20 MHz.
I attached some photos of how it looks like when its not disassembled, as I have already taken it apart for cleaning and repair.
I know very little about this tech.
Only from what I was able to learn online in few days I have it but I am excited and willing to learn much more.
I noticed it has issues, hoping I can get help here and I also have a question or two.
Question #1:Do oscilloscopes have channel A on by default ?
On this oscilloscope, if both channel A and B are off, channel A beam is shown.
Manual however states following(used Google translate from Slovenian to English) :
A,B - button for choosing the mode of operation of the vertical amplifier.
If button A, or B is pushed in, channel A, or B is on.
If both buttons are pushed in, both channels work alternatively or via "chopper", depending on the continued speed of the time base.
Triggering in that case is only through the A channel.
This means that in the case when the oscilloscope works as a two-channel, it is not possible to trigger the time base via channel B.
In that case, we have to replace the inputs.
[b]If both buttons are pushed out, the operation is not regular[/b].
Video that showcases this :
Now onto the problem with channel A-Channel A , I can't get the beam to appear on the screen, its all the way at the bottom, off screen, unless I switch to 5V, .5V, 50mV and 5mV(yes, all 5s,
weird but specific? ) (talking about volts/div dual knob)
In this case I can only get the beam slightly above middle of the screen.
Also, specifically on 5V position, if I wiggle the big knob, the one that clicks, beam will twitch or jump up and down the screen(fixed by cleaning volts/div potentiometer and its contacts, image below in reply)
Video of that here :
But for some reason both knob that adjusts the vertical height, and small knob on Volts/div(I assume it means Volts per division) , they both affect vertical position of the beam(video below that shows this).
This oscilloscope has sort of a dual knob, it consists of big knob and small knob on top of big one and it looks like this
Big knob clicks in place, and can be moved to 20v to 10v to 5v,2V,1V, .5V, .2V, .1V, 50mV, 20mV, 10mV and 5mV.
It can not be moved in between, only to set positions I just mentioned.
Small knob doesn't click, instead it just rotates smoothly like regular knob does.
I assume this small knob is for fine adjustment like getting to 13v/division or something like that ? Same dual knobs can be seen here, it says "CAL" on it
https://youtu.be/5F92iSgEQ-M?t=56-Pressing beam finder button does show that beam is there, just off screen
-There is a button that makes the beam move from left to right if switched on or make it stationary if off, and indeed it works.
Both channels beams do move or stay in place depending on this button,if switched on or off.
Video that showcases channel A problems, I go over what happens on every position :
