Thanks very much for your replies, Armadillo and Oldway.
I should take the opportunity to clarify the capabilities / characteristics of this welding power supply. It's a 240 volt, single phase, 60 Hz, 300 amp output, AC / DC and CC / CV machine. 13 kW. Manufactured in mid 1995. It's a big, heavy transformer-based stationary shop welder designed to handle all metals and processes.
Oldway - there is a power resistor (R4 in FSM, 5 Ohms, 300 W) used for SCR holding current when the welder is in CV mode. Upon close inpection, I discovered a broken Nichrome leg on it, which I have patched up for testing here. However, it reads out of spec at 10 Ohms. I've hooked up the second channel to the rectifier output, but unfortunately I dont presently have an R47 100W resistor on hand to do as you suggest.
Armadillo - Whilst appreciating that the time bases differ widely, what's interesting to me is that subsequent to repairing the resistor the pulse waveform shape has now changed. The scope shows it has lost the negative voltage dip and assumed a form more in line with the FSM example.
Still no output from the rectifier, however. But I'm hoping we are on the right track with this outcome. Could the 5 ohm discrepancy make the difference here?
I've attached the latest waveform pics for your kind review at your convenience. The entire FSM is too big at 1.95 Mb so I'll upload other separate relevant portions / sheets shortly in a separate post.
Also attached is the OEM parts list for the control board with component values. Hope that helps.
