I recently acquired a very nice Yamaha PS-55 keyboard (from 1983 I believe). It sounds great, if it works
Problem is, 9 out of 10 times switching the keyboard on, only the Rhythm section works, but not the Orchestra or Solo sounds. In the event the Orchestra and Solo voices do work, they keep working as long as the keyboard is switched on.
The keyboard has separate ICs for the Rhythms, Solo and Orchestra voices as can be seen in the attached circuit diagram.
Examining the circuit diagram I suspected the 'initial clear' circuit (connected the the reset-in line of the CPU) to be malfunctioning, resulting in the Solo and Orchestra ICs not getting initialized correctly at power on. I've replaced the cap in that circuit without effect.
From the CPU the reset-out goes to the Rhythm IC's Initial Clear-in (IC-in) which in turn according to the schematics produces the IC out for the Solo and Orchestra ICs. This IC-out line seems to be a direct connection without any components in between.
How should I proceed in tracing down this issue?
Your help is much appreciated!
