Author Topic: Vintage/Classic Chassis/Mechanical Renovation/Restoration Techniques  (Read 315114 times)
Offline VK5RCTopic starter
Re: Vintage/Classic Chassis/Mechanical Renovation/Restoration Techniques
« Reply #100 on: January 10, 2022, 07:26:28 am »
xrunner did a high level button recreation using a 3D printed button - sanded, primed then painted.
 He gives away some secrets on reply # 110705 in the TEA section https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/msg3926399/#msg3926399
Thanks
Offline Tubesrule
« Reply #101 on: July 16, 2022, 01:11:58 am »
My little contribution to the thread, nothing like the stuff here. But I'm pretty happy, is an odd duck. Still need to sort out the cable, the original was replaced by a modern one but is beat up and not attached properly. The magic eye!!
Hobbies too many, all expensive and time consuming!!
The following users thanked this post: xrunner, technogreek
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #102 on: July 16, 2022, 05:14:39 am »
Does anyone know a good way to reapply white lettering onto flat panels, like the red plastic used on the displays on 80's HP gear and on Tek TM500 modules?
It would be simple with a laser printer if I could print white.....
Offline Tubesrule
« Reply #103 on: July 18, 2022, 01:09:57 am »
Hi anyone here can id, this type of rivet. Trying to keep it as original as possible.
Thanks
« Reply #104 on: July 18, 2022, 09:01:27 am »
Hollow brass rivet, Mcmaster carr will have them, though you might have to order a pack of 100 of them. Otherwise hobby shops tend to have thin wall brass tubing that you can use to make them, just cut a small piece off ( use a drill bit shaft that is a snug but sliding fit in the tube, then grind the tube to cut it as an easy way to not crush it) then flare out the one end, insert then flare out the other end.
The following users thanked this post: Tubesrule
Offline manicdoc
    • Aykira Internet Solutions
« Reply #105 on: August 25, 2022, 11:10:35 pm »
Got a TDS540 with 3 feet, so needed another one... found this
https://www.printables.com/model/22192-replacement-feetpads-for-tektronix-tds-500600700-s/files
Covers series 500/600/700
Offline tautech
« Reply #106 on: August 25, 2022, 11:24:24 pm »
There is also this useful thread in the TE board with a # of Tek listings one of which has the 5,6,700 feet.
https://www.eevblog.com/forum/testgear/replacement-knobs-feet-and-fittings-for-test-equipment/
Avid Rabid Hobbyist
Can help with advice on Siglent equipment when time allows.
Offline technogreek
« Reply #107 on: October 20, 2022, 08:59:34 pm »
Hi- Need some help identifying the manufacturer (or possible successor) of this type PCB board to cable connector.  Only marking is "OTP" .  These are from approx 30-40 year old boards made in Japan.  Other components all look to be Japenese manfacturers.  Thanks
« Reply #108 on: November 03, 2022, 08:30:50 am »
@technogreek what is the pin spacing - and approx pin diameter, is the socket expecting a square, rectangular or round pin? From the photo it looks like a 0.1" pin sockets - but hard to guess.
Offline technogreek
« Reply #109 on: November 03, 2022, 03:19:47 pm »
as close as I can measure-- 2.5mm (0.1") pitch, square pins maybe 0.6mm(0.024") looks like a spring type latch, meaning it snaps into an opening in the socket
thanks for responding.  these old connectors are difficult!
Offline DavidKo
  • Country: cz
« Reply #110 on: November 03, 2022, 04:11:00 pm »
Does it fit on standard 2.54 header? Example picture of header in https://kr.misumi-ec.com/vona2/detail/222005577741/. In case you need also the locking, than it will be harder.
The following users thanked this post: technogreek
Offline mag_therm
« Reply #111 on: November 03, 2022, 04:17:54 pm »
They look similar to JAE IL-G series, if 2.50mm pitch
The JAE 0.1 inch pitch is not in latest catalog
https://www.jae.com/en/technical/catalog/
The JAE cable contacts are separate part number on a reel and click in after crimping.
Crimper was special. the contacts can be hand soldered to wire if care is taken to minimise solder so the crimp ears can be bent in
If you have to change both the pcb header and cable side, I use Phoenix contact PTSM
https://www.phoenixcontact.com/en-us/products/pcb-header-ptsm-05-4-hv-25-thr-r32-1778573
4 pin example:
PCB header - PTSM 0,5/ 4-HV-2,5-thr r32
Cable Plug - PTSM 0,5/ 4-P-2,5-
The cable plugs have push-in locking receptacles I have used AWG 22 and 24 stranded.
The 4 pin width fits 0.1 inch pcb OK. 8 pins would have 0.32mm length error over length, might still be OK for a repair job
Offline technogreek
« Reply #112 on: November 03, 2022, 11:25:44 pm »
Good thought, hadn't tried a 2.54 header.  I just tried and the spacing is just large enough to through off anything larger than the 2 pin connection.
I appreciate your input.
Offline technogreek
« Reply #113 on: November 10, 2022, 12:38:12 pm »
Thanks, i’ll investigate your links. Don’t think i can find the originals for replacement, so Plan B!
Offline David D
« Reply #114 on: April 13, 2023, 10:20:21 pm »
New guy here!
I have searched and cannot find any info on the frosted/anti-glare coating that HP used on the front panels of the 90's gear like my 8903B. Apparently, it had some stickers on it at one time and when they peeled them off, the coating came off as well. I've thought about trying some matt or frosted clear spray paint, but would like to know if anyone else has delt with this before.
« Last Edit: April 17, 2023, 05:27:18 pm by David D »
