Author Topic: Vizio E241-A1  (Read 1690 times)
Offline neoTopic starter
  • The specialist.
Vizio E241-A1
« on: March 14, 2018, 01:58:00 am »
I really need help here, please and thank you. Original problem, would not turn on.
Screen is fine, worked when i last used it and got a visible confirmation when working on it.
I then replaced the power supply board, no change and it acted odd when i plugged in the digital board.
Replaced the digital board, and it has made progress. I can now turn it on but the screen doesn't come on and it won't turn off without unplugging it.
Power supply is new, the main board is tested and warrantied.
Without digital board 5.2V measured as 5.25V and the 16V measured as 15.6V
With digital board 5.2V measured as 5.138V and the 16V measured as 18V
Offline Rasz
    • My random blog.
Re: Vizio E241-A1
« Reply #1 on: March 14, 2018, 04:50:05 pm »
is it? who tested it? :)
does it act same with panel not plugged in?
The following users thanked this post: neo
  • The specialist.
Re: Vizio E241-A1
« Reply #2 on: March 14, 2018, 05:05:55 pm »
Electroparts, a company who warrantied it.
With the panel completely disconnected, that is to say both plugs unplugged, yes it does. Just checked it.
Offline Rasz
    • My random blog.
Re: Vizio E241-A1
« Reply #3 on: March 15, 2018, 12:29:05 am »
Well, one of the two is bad, supply or logic board. Its easier to confirm supply and I assume you already did that, Im guessing you got a bad logic board.
  • The specialist.
Re: Vizio E241-A1
« Reply #4 on: March 15, 2018, 12:48:26 am »
Well i can only confirm the 5V and 16V, no clue what comes out the other pin header and even if i did i can't make it turn on. But given the supply is new and the digital board ain't should i try to return the digital board? Or just give up on the thing?
Offline Rasz
    • My random blog.
Re: Vizio E241-A1
« Reply #5 on: March 15, 2018, 02:33:09 am »
no idea :(
the old supply is dead?
  • The specialist.
Re: Vizio E241-A1
« Reply #6 on: March 15, 2018, 02:56:45 am »
no idea :(
Maybe, maybe not. It is crusty due to my repair attempts.
I think not turning on = death for these things.  :(
