Hi all, long time viewer of Dave's, first time poster.
I have a medical grade psu, the VLT110-4302, that has gone bad on me. After watching the combiscope diagnosis/repair, I was inspired to try to get it working again.
It's a quad output, with +/- 5V and 15V rails. The power good signal is used to drive a chassis fan, but I don't get fanspin or anything on the outputs of the supply.
The main input caps go to 160Vdc which seems sane, and all of the output caps seem to measure fine... no dead shorts at all. Two of the output caps are 6.3V, and I don't get a good reading on them, but I haven't removed anything from the board yet.
The main rail has a current shunt at 100ohms (4 digit coded precision), but reads slightly below at 85-90ohms... not sure if that's an issue.
If you have any recommendations for getting this diagnosed, I would be grateful.
thanks,
bob
