Hi all,
I got this DMM for about 3 weeks and used it only a few times.
Anyway, a few days ago I noticed that the voltage reading are 10 times higher than it should be.
And the resistance measurment shows 87 ohm when the probes are not measuring anything, in fact it shows 87 ohm even if the probes are disconnected.
I opened the DMM and looked for something burned or shorts on the PCB such as the resistors diveders and capacitors but didn't find such.
And the rest of the functions- mA, capacitance, temp are working fine.
I also clened the PCB with Alcohol but didn't help.
* the seller offered to refund me, but I want to fix it(atleast to try)
Any ideas to what to do next?
thanks
