I've just witnessed an impressive but disturbing failure of a ceiling fixture (115V in US). It has two bulbs and the wire to one caught fire. I had turned it on a couple of minutes earlier. The fixture is part of a three-way lighting circuit.
Anyway, while checking the voltages with my DMM, I came across something strange. With the fixture completely removed and just the cable coming out the ceiling (hot, neutral + ground) I got the following readings:
Switched on:
Hot-Neutral: 120V
Hot-Ground: 120V
Neutral-Ground: 0V
(all well and good)
Switched off:
Hot-Neutral: 42V
Hot-Ground: 42V
Neutral-Ground: 0V
(not so good, right?)
What do I need to check?
Thanks.
