Author Topic: Voltcraft 2080 oscilloscope troubleshooting  (Read 5083 times)
Offline EinkleinermenschTopic starter
« on: October 01, 2017, 12:03:39 pm »
Hello guys! I've got by occasion an old Voltcraft 2080 oscilloscope and trying to check it's operation as described in it's manual (I've made some photos of it). Until step 20 everything works good but there is a second "ghost" signal image on the screen. It is much darker than main oscillation image, but still visible (see photo 5). When I do steps 20-24 it seems to be working, I can magnify a portion of signal (photo 6). At step 25 when I set TIME/DIV to 10 us/DIV, I get no image of edges even by adjusting DELAY TIME POSITION drive. Actually, the signal line becomes pretty short and not adjustable instead of showing me a signal edge (photo 7). Is it a problem with a sweep generator or with one of timebase cirquits? What can couse this problem? Thank you!
(I'm sorry for my bad english  :) )
Offline Armadillo
Re: Voltcraft 2080 oscilloscope troubleshooting
« Reply #1 on: October 01, 2017, 01:24:07 pm »
I can't visualize clearly, but I think is a retrace line problem.
You need to check and adjust the retrace line blanking control.
Edit: Have you recently done anything to the oscilloscope?
Edit: Adjust VR540 until ghost disappeared.
If this solved your problem, I would advise you to do total re-alignment, adjustment and calibration especially on all the power supply voltages and bias control.
Unfortunately the service manual is in foreign language, can't read it any further.   :phew:
« Last Edit: October 01, 2017, 01:54:28 pm by Armadillo »
Offline Le_Bassiste
« Reply #2 on: October 01, 2017, 03:30:23 pm »
you may want to check the DELAYED TIMEBASE setting. did you make sure that it is switched to something like "MAIN ONLY" or "OFF"?
An assertion ending with a question mark is a brain fart.
Offline StillTrying
  • Country: Broken Britain
« Reply #3 on: October 01, 2017, 04:07:39 pm »
"At step 25 when I set TIME/DIV to 10 us/DIV, I get no image of edges even by adjusting DELAY TIME POSITION drive. Actually, the signal line becomes pretty short and not adjustable instead of showing me a signal edge (photo 7)."
When step 25 says set TIME/DIV to 10 us/DIV. it must mean the DELAYED TB speed, it doesn't make much sense the have the MAIN on 10us/Div and the DELAYED on the 100us/Div.
Only the 1st photo looks wrong to me, sometimes there's a switch setting to make the MAIN or DELAYED part of the trace the brightest.
« Reply #4 on: October 01, 2017, 04:13:33 pm »
Armadillo, thank you, when I opened the oscilloscope, I've found that VR540 seems to be broken by previous owner: its cap was just separated from its body. I'll buy a new one tomorrow and try to adjust.
No, just opened its housing.
Hmm, how can I do this? If you mean the MAIN/MIX/DELAY switch, I've used it as described in operator's manual.
UPD:
Thank you, I understand now. I've tried to switch DELAY to 10 us, now it shows something that supposed to be the edge, but it is not as showed in manual, see the attachment. Even at 2 us Delay I'm unable to make it longer.
« Last Edit: October 01, 2017, 04:29:18 pm by Einkleinermensch »
Offline StillTrying
« Reply #5 on: October 01, 2017, 06:17:18 pm »
"I've tried to switch DELAY to 10 us, now it shows something that supposed to be the edge, but it is not as showed in manual,"
The manual's Fig 4-3 showing a 20us risetime edge is just a diagram, your 1kHz's actual rise and fall times will be only ~0.2us, which is 100X faster than the diagram. So your last photo looks about right to me.
Delayed timesbase's are always fiddly to use, there might be nothing much wrong with it. Most of the time I think you're better off just using the X-POS, PULL X10 instead!
Offline carl_lab
« Reply #6 on: October 02, 2017, 10:42:41 am »
The scope looks similar to an older HAMEG scope (HM203, HM303...?).
Don't know if that could help you...
« Last Edit: October 02, 2017, 07:35:31 pm by carl_lab »
Online Kleinstein
« Reply #7 on: October 03, 2017, 05:17:50 pm »
The ghost image could be from the "mix" mode of the delay switch. It is there to indicate the part that you will see with delay active. I have the slower version (2020 of that scope). If I remember right it uses two intensities. The delayed mode is not used very often - many simple scopes don't have it at all. I have not used it the last 15 years or so.
A double image could also be caused by bad triggering, sometimes triggering an a wrong edge. However at least the 2020 is rather good in triggering - better than the similar Hameg ones (e.g 203).  Especially the extra hold off knob helps if the repeat frequency is just at the edge. The instructions should include a full schematics - so no problem there.
« Reply #8 on: October 04, 2017, 02:30:13 pm »
Thank you guys! I've changed the broken resistor, but it's adjusting seems to do nothing. A ghost image is still on the screen in the main mode  :(
Offline Armadillo
« Reply #9 on: October 04, 2017, 03:39:55 pm »
The VR540 cannot be doing nothing to the screen, it plays a distinct role on the screen. There are few prime suspect components there, the optoisolator, transistors, the 2KV capacitors etc.... You should start measuring the voltages around the circuit attached.
Edit: oh please be safe, and don't blame me on your safety and I cannot be responsible for it.  ;D
« Last Edit: October 04, 2017, 03:46:56 pm by Armadillo »
Offline Armadillo
« Reply #10 on: October 04, 2017, 04:01:16 pm »
Measure the voltages based on 2 conditions;
1: turn the VR540 to the left around left 45 degree, measure all the voltages shown by the Red arrows with respect to the ground
2: turn the VR540 to the right around right 45 degree, measure all the voltages shown by the Red arrows with respect to the ground.
Please tell us your measurement.
« Reply #11 on: October 04, 2017, 05:53:16 pm »
So here are the measurements:
VR540 45 degrees to the left:
          D541 (Anode): -1258V
          On Q541's collector: -1258V
          Between R548 and R551: 12.00V
          U541 (1,4,5): 0.92V, -1258V, -1258V
VR540 45 degrees to the right:
          U541 (1,4,5): 1.01V, -1258V, -1258V
Offline Armadillo
« Reply #12 on: October 04, 2017, 06:02:01 pm »
Is that a minus voltage I am looking at? Can you re-measure it for confirmation.
Edit: Turn off the power supply. Use multimeter on diode Mode, check Pin 1 and Pin 2 of U541, forward and reverse. The LED seems like not drawing any current.
Edit: It is optoisolated, so maybe different ground reference potential. But the optoisolator seem like not working. Please change U541.
Except Pin 1 and Pin 2, Please measure the voltages of the rest of the measurement points with respect to emitter of Q541.  [The result should be the same, indicating that the optoisolator is not conducting but at least we seeing positive voltage with the correct reference ground now.]
Edit: Order 4N25 and change a new one.
« Last Edit: October 04, 2017, 06:34:39 pm by Armadillo »
Offline Armadillo
« Reply #13 on: October 04, 2017, 06:27:00 pm »
After you installed the new U541, remember to return VR540 to Mid Position before turn On.
After turn on, then slowing adjust until ghost image disappeared.
« Reply #14 on: October 04, 2017, 06:58:07 pm »
Thank you, I've ordered a new optocoupler!
I've measured all voltages with respect to Q541's emitter: It is all around 1V in every point except between R548 and R551, in this Point it's more then -1800V (my multimeter can't measure such high voltages).
I've checked also U541's pin 1 and 2 at switched off power supply: it's 1.6V by direct switching and 1V in reverse, seems like really dead diode.
Offline Armadillo
« Reply #15 on: October 04, 2017, 07:09:36 pm »
At ~31volt transformer, you cannot be measure 1V. So can you please re-measure as per attached markup sketch. Yes do change the U541.
« Reply #16 on: October 04, 2017, 07:41:27 pm »
It is 0V on both capacitors and 0.5V on the Zener. Maybe one of capacitors is dead?
« Last Edit: October 04, 2017, 07:42:59 pm by Einkleinermensch »
Offline Armadillo
« Reply #17 on: October 04, 2017, 08:25:14 pm »
Take out the Electrolytic and check it. Check the diode also. Measure the AC 31 voltages whether it is there. Check why in case not there. You found the defective circuit.
« Reply #18 on: October 04, 2017, 08:45:31 pm »
Thank you for your help! I'll find the problem :)
« Reply #19 on: October 07, 2017, 01:49:46 pm »
Well, I've changed the optocoupler, tested all diodes in that cirquit and gave a look to an electrolytic. Everything seems fine. I've tried to disconnect that 3-pin connector "~31V, ~6.3V, Ref" and measured first 2 voltages in respect to ref. They both are around -3V to the Ref pin. Can it be possible that something happened to the transformer?
Offline Armadillo
« Reply #20 on: October 07, 2017, 02:13:16 pm »
If you can't even get close to ~31V unplugged, then likely the transformer is faulty.     :(
« Reply #21 on: October 07, 2017, 03:16:52 pm »
Maybe the transformer is unified so I can look up for the same or similar :)
Offline Armadillo
« Reply #22 on: October 07, 2017, 05:36:27 pm »
Trace for dry joints at connectors, broken traces etc until you trace the wires back to the transformer.
« Reply #23 on: October 07, 2017, 09:56:23 pm »
The 31V wire comes directly from the transformer. The resistance between ref wire and 31V is way more than 10 MOhm, so it's either somehow broken winding or just a bad contact between wire and transformer's pad. I'll give it a closer look tomorrow. If the problem is in the winding, I'll just make a small AC-DC converter for 31*sqrt2=44V and take some power from 6.3V bus. The 31V supply needs around 0.125W, and 6.3V bus' max power rating is 0.95 W, so I think there's enough power to drive both buses.
