Hello,
At first I would like to say hi to everyone, I am completely new to this forum (although I have been watching Dave videos for years)
I would like to ask for help in repairing the VOLTCRAFT DSO-1084E oscilloscope (Hantek DSO4084B). I bought it for a penny (already damaged) hoping that I would be able to do something with it. Unfortunately, I got stuck
I checked other threads on the forum and I found nothing similar to this.
Oscilosope is stuck on Logo/Boot screean or after "hard reset" in recovery screan with information "System is not shut down properly..."
Logs from "normal" startup:
system reboot
“OM*** Warning - bad CRC, using default environment
##### EmbedSky BIOS for SKY2416/TQ2416 #####
This Board: SDRAM is 64MB; Press Space key to Download Mode.!
NAND read: device 0 offset 0x380000, size 0x800
2048 bytes read: OK
**************************normal start*******************************
NAND erase: device 0 offset 0x380000, size 0x80000
Erasing at 0x380000 -- 25% complete.
Erasing at 0x3a0000 -- 50% complete.
Erasing at 0x3c0000 -- 75% complete.
Erasing at 0x3e0000 -- 100% complete.
OK
NAND write: device 0 offset 0x380000, size 0x800
Writing data at 0x380000 -- 0% complete.
Writing data at 0x380800 -- 100% complete.
2048 bytes written: OK
2048 bytes read: OK
Saving Environment to NAND...
Erasing Nand...
Warning: Erase size 0x00004000 smaller than one erase block 0x00020000
Erasing 0x00020000 instead
Erasing at 0x80000 -- 100% complete.
Writing to Nand... done
NAND read: device 0 offset 0x400000, size 0x400000
4194304 bytes read: OK
Boot with zImage
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 3.2.35 (root@zgt) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-176) ) #22 PREEMPT Fri Oct 27 02:56:10 CST 2017
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: SMDK2416
Ignoring unrecognised tag 0x54410008
Memory policy: ECC disabled, Data cache writeback
CPU S3C2416/S3C2450 (id 0x32450003)
S3C24XX Clocks, Copyright 2004 Simtec Electronics
CPU: MPLL on 800.000 MHz, cpu 400.000 MHz, mem 133.333 MHz, pclk 66.666 MHz
CPU: EPLL on 96.000 MHz, usb-bus 48.000 MHz
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: noinitrd ubi.mtd=5 ubi.mtd=6 root=ubi0:rootfs rootfstype=ubifs init=/linuxrc console=ttySAC0 lcd=X480Y272
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 58948k/58948k available, 6588k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xc4800000 - 0xf6000000 ( 792 MB)
lowmem : 0xc0000000 - 0xc4000000 ( 64 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc03fc000 (4048 kB)
.init : 0xc03fc000 - 0xc041b000 ( 124 kB)
.data : 0xc041c000 - 0xc05b5200 (1637 kB)
.bss : 0xc05b5224 - 0xc05d2fdc ( 120 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:107
irq: clearing subpending status 00000002
Calibrating delay loop... 198.45 BogoMIPS (lpj=496128)
pid_max: default: 4096 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
S3C2416: Initializing architecture
S3C2416: IRQ Support
S3C24XX DMA Driver, Copyright 2003-2006 Simtec Electronics
DMA channel 0 at c4804000, irq 88
DMA channel 1 at c4804100, irq 89
DMA channel 2 at c4804200, irq 90
DMA channel 3 at c4804300, irq 91
DMA channel 4 at c4804400, irq 92
DMA channel 5 at c4804500, irq 93
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
s3c-i2c s3c2410-i2c: slave address 0x10
s3c-i2c s3c2410-i2c: bus frequency set to 9 KHz
s3c-i2c s3c2410-i2c: i2c-0: S3C I2C adapter
Advanced Linux Sound Architecture Driver Version 1.0.24.
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
s3c-adc s3c24xx-adc: attached adc driver
msgmni has been set to 115
io scheduler noop registered (default)
io scheduler cfq registered
s3c-fb s3c-fb: window 0: fb
s3c-fb s3c-fb: LCD type is TN83 800*480, default_bpp=16, pixclock=5
s3c-fb s3c-fb: window 1: fb
s3c2440-uart.0: ttySAC0 at MMIO 0x50000000 (irq = 70) is a S3C2440
console [ttySAC0] enabled
s3c2440-uart.1: ttySAC1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: ttySAC2 at MMIO 0x50008000 (irq = 76) is a S3C2440
s3c2440-uart.3: ttySAC3 at MMIO 0x5000c000 (irq = 94) is a S3C2440
loop: module loaded
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
info->cpu_type=3, tacls_max=8
s3c24xx-nand s3c2416-nand: Tacls=3, 22ns Twrph0=7 52ns, Twrph1=3 22ns
s3c24xx-nand s3c2416-nand: System booted from NAND
s3c24xx-nand s3c2416-nand: NAND ECC disabled
NAND device: Manufacturer ID: 0xc8, Chip ID: 0xd1 (Unknown NAND 128MiB 3,3V 8-bit)
NAND_ECC_NONE selected by board driver. This is not recommended!
Scanning device for bad blocks
Bad eraseblock 726 at 0x000005ac0000
Creating 9 MTD partitions on "NAND":
0x000000000000-0x000000100000 : "uboot"
0x000000100000-0x000000180000 : "params"
0x000000180000-0x000000380000 : "logo"
0x000000380000-0x000000400000 : "misc"
0x000000400000-0x000000800000 : "kernel"
0x000000800000-0x000003a00000 : "rootfs"
0x000003a00000-0x000004e00000 : "config"
0x000004e00000-0x000005200000 : "kernel_bk"
0x000005200000-0x000008000000 : "recover"
UBI: attaching mtd5 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 71
UBI: attached mtd5 to ubi0
UBI: MTD device name: "rootfs"
UBI: MTD device size: 50 MiB
UBI: number of good PEBs: 400
UBI: number of bad PEBs: 0
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 6
UBI: total number of reserved PEBs: 394
UBI: number of PEBs reserved for bad PEB handling: 4
UBI: max/mean erase counter: 2/1
UBI: image sequence number: -1570950245
UBI: background thread "ubi_bgt0d" started, PID 341
UBI: attaching mtd6 to ubi1
UBI: max. sequence number: 2038
UBI: attached mtd6 to ubi1
UBI: MTD device name: "config"
UBI: MTD device size: 20 MiB
UBI: number of good PEBs: 160
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 160
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 15/13
UBI: image sequence number: 0
UBI: background thread "ubi_bgt1d" started, PID 344
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usbcore: registered new interface driver usblp
usbcore: registered new interface driver uas
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
samsung-ts s3c2416-ts: driver attached, registering input device
input: S3C24XX TouchScreen as /devices/virtual/input/input0
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
i2c /dev entries driver
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq disabled
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
s3c-sdhci s3c-sdhci.1: clock source 0: hsmmc (133333333 Hz)
s3c-sdhci s3c-sdhci.1: clock source 1: hsmmc (133333333 Hz)
s3c-sdhci s3c-sdhci.1: clock source 2: hsmmc-if (24000000 Hz)
mmc0: SDHCI controller on samsung-hsmmc [s3c-sdhci.1] using ADMA
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
S3C24XX_UDA134X SoC Audio driver
S3C24XX_UDA134X SoC Audio: l3 data pin already in use
s3c24xx_uda134x: probe of s3c24xx_uda134x.0 failed with error -16
ALSA device list:
No soundcards found.
TCP cubic registered
NET: Registered protocol family 17
Registering the dns_resolver key type
s3c-rtc s3c2410-rtc: setting system clock to 2022-02-16 03:56:02 UTC (1644983762)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 47869952 bytes (46748 KiB, 45 MiB, 377 LEBs)
UBIFS: journal size: 2412544 bytes (2356 KiB, 2 MiB, 19 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 2261015 bytes (2208 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:10.
Freeing init memory: 124K
Failed to execute /linuxrc. Attempting defaults...
Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
Logs from "recovery" startup:
vice 0 offset 0x4e00000, size 0x400000
Boot with zImage
Starting kernel ...
Machine: SMDK2416
Kernel command line: noinitrd ubi.mtd=8 root=ubi0:recover rootfstype=ubifs init=/linuxrc console=ttySAC0 lcd=X480Y272
NR_IRQS:107
TCP reno registered
loop: module loaded
UBI: attaching mtd8 to ubi0
UBI: max. sequence number: 334
UBI: attached mtd8 to ubi0
UBI: MTD device name: "recover"
UBI: MTD device size: 46 MiB
UBI: number of good PEBs: 367
UBI: number of bad PEBs: 1
UBI: total number of reserved PEBs: 367
UBI: number of PEBs reserved for bad PEB handling: 3
s3c-rtc s3c2410-rtc: rtc disabled, re-enabling
ALSA device list:
s3c-rtc s3c2410-rtc: setting system clock to 2022-02-16 07:03:39 UTC (1644995019)
UBIFS: mounted UBI device 0, volume 0, name "recover"
UBIFS: file system size: 44314624 bytes (43276 KiB, 42 MiB, 349 LEBs)
UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
Please press Enter to activate this console. dso-iobank: install ok
0x505
gpio_major_n = 5, io_minor_n = 5, output 0
0x603
gpio_major_n = 6, io_minor_n = 3, output 0
0x70a
gpio_major_n = 7, io_minor_n = 10, output 0
AFG3050 fpga configure init
fpga bank 11811
input: dso_kbd as /devices/virtual/misc/dso-fpga/input1
dso-fpga: install ok
user file is /lib/firmware/dn.rbf
nstatus0 :0x0
nstatus1 :0x1
fpga state :0x1
file len is 456524
FPGA CONFIGURE DATA DOWN finish.0x1, 0
FPGA CONFIGURE ok.
ls -la
-/bin/sh: source: line 10: can't open '/dso/etc/profile'
[root@Hantek ~]#
[root@Hantek ~]#ls -la
total 4
drwxr-xr-x 17 root root 1256 Feb 16 04:04 .
drwxr-xr-x 17 root root 1256 Feb 16 04:04 ..
-rw------- 1 root root 3008 Feb 16 07:03 .ash_history
drwx------ 2 root root 304 Aug 10 2021 .gnupg
drwxr-xr-x 2 root root 6496 Mar 8 2018 bin
drwxr-xr-x 3 root root 0 Feb 16 07:03 dev
drwxr-xr-x 2 root root 160 Mar 8 2018 dso
drwxr-xr-x 4 root root 816 Mar 8 2018 etc
drwxr-xr-x 4 root root 3664 Mar 8 2018 lib
lrwxrwxrwx 1 root root 11 Mar 8 2018 linuxrc -> bin/busybox
drwxr-xr-x 8 root root 544 Feb 16 06:29 mnt
dr-xr-xr-x 48 root root 0 Jan 1 1970 proc
drwxr-xr-x 4 root root 1168 Feb 16 06:02 recover
drwxr-xr-x 2 root root 232 Feb 16 04:49 root
drwxr-xr-x 2 root root 4320 Mar 8 2018 sbin
drwxr-xr-x 11 root root 0 Feb 16 07:03 sys
drwxr-xr-x 2 root root 0 Feb 16 07:03 tmp
drwxr-xr-x 5 root root 360 Mar 8 2018 usr
drwxr-xr-x 2 root root 0 Feb 16 07:03 var
[root@Hantek ~]#
[root@Hantek ~]#
I am able to execute linux commands only after starting in recovery mode.
I found most directories are just empty, for example
/dso:
[root@Hantek ~]#ls -la /dso
total 0
drwxr-xr-x 2 root root 160 Mar 8 2018 .
[root@Hantek ~]#
[root@Hantek ~]#
Then I noticed that it is impossible to mount the pendrive (FAT32), I only get the message:
mount: mounting /dev/sda1 on /mnt/usb failed: Invalid argument
This led me to a clue, so I started checking what's in the
/mnt directory. And it looks like almost everything is empty or not mounted (?)
ls -la
total 0
drwxr-xr-x 8 root root 544 Feb 16 06:29 .
drwxr-xr-x 2 root root 160 Aug 27 2018 config
drwxr-xr-x 2 root root 160 Mar 8 2018 nfs
drwxr-xr-x 2 root root 160 Aug 27 2018 rootfs
drwxr-xr-x 2 root root 160 Mar 8 2018 sd
drwxr-xr-x 2 root root 160 Mar 8 2018 udisk
drwxr-xr-x 2 root root 160 Feb 16 06:29 usb
[root@Hantek /mnt]#
[root@Hantek /mnt]#ls -la config
total 0
drwxr-xr-x 2 root root 160 Aug 27 2018 .
drwxr-xr-x 8 root root 544 Feb 16 06:29 ..
[root@Hantek /mnt]#
[root@Hantek /mnt]#ls -la nfs
total 0
[root@Hantek /mnt]#
[root@Hantek /mnt]#ls -la rootfs
total 0
[root@Hantek /mnt]#
[root@Hantek /mnt]#ls -la udisk
total 0
[root@Hantek /mnt]#
[root@Hantek /mnt]#
After that, I also tried to insert the microSD card and see what will happen (currently I don't even know how to copy something to the oscilloscope). The oscilloscope would freeze then endlessly attempting to mount the card:
mount: mounting /dev/mmcblk0p1 on /mnt/sd failed: Invalid argument
I don't know what to do next. Maybe except that I found the script in the
/recover directory:
#!/bin/sh
#lcd show bin & file
LCD_BIN_SHOW=/recover/lcd-show-recover
DRIVER1=/recover/spidev.ko
DRIVER2=/recover/spi-s3c64xx.ko
DRIVER3=/recover/fpga_cfg.ko
DRIVER3_BIN=/recover/cfg_fpga
DRIVER4=/recover/keyboard.ko
DRIVER5=/recover/s3c2416-io_bank.ko
DRIVER5_BIN=/recover/io_bank
#partiton info
MISC_PARTITION=/dev/mtd3
KERNEL_PARTITION=/dev/mtd4
ROOTFS_PARTITION=/dev/mtd5
CONFIG_PARTITION=/dev/mtd6
#image file name
KERNEL_IMAGE_FILE=/recover/kernel.bin
ROOTFS_IMAGE_FILE=/recover/rootfs/rootfs.tar.bz
CONFIG_IMAGE_FILE=/recover/config/
UPDATE_FLAG_FILE=/recover/update_flag
#commond
INIT=init
RECOVER=recover
if [ $1 == $INIT ] ; then
#install drivers
if [ -f $DRIVER5 ] ; then
insmod $DRIVER5
fi
if [ -f $DRIVER5_BIN ]; then
$DRIVER5_BIN f5 o 0
$DRIVER5_BIN g3 o 0
$DRIVER5_BIN h10 o 0
fi
if [ -f $DRIVER2 ] ; then
insmod $DRIVER1
insmod $DRIVER2
fi
if [ -f $DRIVER3 ] ; then
insmod $DRIVER3
fi
insmod $DRIVER4
if [ ! -d /mnt/config ]; then
mkdir /mnt/config
fi
if [ ! -d /mnt/rootfs ]; then
mkdir /mnt/rootfs
fi
if [ -f $DRIVER3_BIN ]; then
$DRIVER3_BIN /lib/firmware/dn.rbf
fi
sleep 1
$LCD_BIN_SHOW
elif [ $1 == $RECOVER ] ; then
if [ $2 -eq 0 ] ; then
flash_eraseall $MISC_PARTITION
elif [ $2 -eq 1 ] ; then
#recover start
if [ ! -f /recover/recover_end ]; then
exit 1
fi
flash_eraseall $KERNEL_PARTITION
nandwrite -p $KERNEL_PARTITION $KERNEL_IMAGE_FILE
flash_eraseall $ROOTFS_PARTITION
if ubiattach /dev/ubi_ctrl -m 5 ; then
ls
fi
if ubimkvol /dev/ubi1 -N rootfs -s 49000000 ; then
ls
fi
mount -t ubifs ubi1:rootfs /mnt/rootfs
tar jxvf $ROOTFS_IMAGE_FILE -C /mnt/
rm /mnt/root/system.inf
if cat /proc/mtd | grep "config"; then
flash_eraseall $CONFIG_PARTITION
if ubiattach /dev/ubi_ctrl -m 6 ; then
ls
fi
if ubimkvol /dev/ubi2 -N config -s 19000000 ; then
ls
fi
mount -t ubifs ubi2:config /mnt/config
fi
cp $CONFIG_IMAGE_FILE/* /mnt/config -a
rm /mnt/config/root/system.inf
fi
#recover end
elif [ $2 -eq 2 ] ; then
#mount fs
ls
fi
ls
fi
ls
fi
ls
fi
fi
#backup
nanddump -o -b -f $KERNEL_IMAGE_FILE $KERNEL_PARTITION -l 3000000
if [ ! -f /mnt/rootfs/linuxrc ]; then
exit 1
fi
if [ -f $ROOTFS_IMAGE_FILE ]; then
rm -f $ROOTFS_IMAGE_FILE
fi
tar jcvf $ROOTFS_IMAGE_FILE rootfs -C /mnt
cp /mnt/config/* $CONFIG_IMAGE_FILE -a
fi
elif [ $2 -eq 3 ] ; then
rm -rf /tmp/update || echo "error ignored"
mkdir /tmp/update
/usr/gpg149arm/bin/gpg --passphrase recoveruse --output /tmp/update/recover tar gz -d /mnt/udisk/recover* up
tar xvzf /tmp/update/recover tar gz -C /tmp/update/
tar xvf /tmp/update/recover* tar -C /tmp/update/
chmod +x /tmp/update/tekwayup_client/update.sh
else
exit 1
fi
else
exit 1
fi
Analyzing it, I came to the conclusion that it might be possible to restore the oscilloscope from backup, but unfortunately there is no backup:
sh ./recover.sh recover 3
gpg: fatal: can't create directory `root/.gnupg': No such file or directory
secmem usage: 32/32 bytes in 1/1 blocks of pool 32/32768
tar: can't open '/tmp/update/recover.tar.gz': No such file or directory
tar: can't open '/tmp/update/recover*.tar': No such file or directory
chmod: /tmp/update/tekwayup_client/update.sh: No such file or directory
./recover.sh: line 156: /tmp/update/tekwayup_client/update.sh: not found
Maybe someone with a similar oscilloscope is able to provide it to me? Although I do not know yet how to copy this backup there
Thanks in advance for your help and time
