Author Topic: Voltcraft R-200 or CEM DT-5302 burnt Resistor  (Read 2300 times)
Offline snikTopic starter
« on: October 01, 2017, 12:51:57 am »
Get this defective  Ohmmeter as "present".
Found a burning Resistor in this meter, but can't see the value anymore...
Is there an owner of this meter Voltcraft R-200 / CEM DT-5032 who can give me the value / Pictures of my burnt resistor R5 on the main PCB?
Thanks
Offline retiredcaps
Re: Voltcraft R-200 or CEM DT-5302 burnt Resistor
« Reply #1 on: October 01, 2017, 02:27:53 am »
If no one can provide a value, I suggest removing the old one and substituting the same value as R6 for test purposes. If meter works, then you can try and get the real value.
Offline Maxelektrix
« Reply #2 on: August 02, 2018, 04:33:32 am »
Please help. that for the component burned out on my board. give labeling
Offline Maxelektrix
« Reply #3 on: August 02, 2018, 04:34:55 am »
give a photo of the top board. I exploded the chip eight contacts.
« Reply #4 on: August 03, 2018, 08:17:30 pm »
I was for my Multimeter in contact with an engenier from CEM, the value of R5 is 15 Ohm.
Offline Maxelektrix
« Reply #5 on: September 11, 2018, 05:01:11 pm »
U4-?
Offline serg-el
  • Country: ru
