Author Topic: Ice Maker Pump Repair  (Read 703 times)
Offline electricMNTopic starter
« on: April 27, 2020, 11:23:55 pm »
Anybody know what manufacturer makes this driver chip? It's marked with "477H" & "8YBG". It's used to drive a 12VDC pump motor used in a counter top ice maker. The motor has four coils. The junction of two of the coils is tied to GND, another junction is tied to one of the outputs, another junction is tied to the other output and the last junction isn't tied to anything.
979804-0  979808-1
« Last Edit: April 27, 2020, 11:26:25 pm by electricMN »
Offline Manul
  • Country: lt
Re: Ice Maker Pump Repair
« Reply #1 on: April 28, 2020, 12:01:01 am »
Not sure about manufacturer of original one, but it is hall effect sensor for example AH477AZ4 from Diodes Inc.
« Reply #2 on: April 28, 2020, 04:10:09 am »
Thank you very much.  :-+
Offline Whales
    • Halestrom
« Reply #3 on: April 28, 2020, 05:47:26 am »
Many 12V computer fans are of a similar design,  one weird-skinny-looking chip that controls the coils and uses hall sensing.  The ones in fans are probably lower wattage/current than what you will find in a water pump, however.
Hope you find a working replacement  :-+
The following users thanked this post: electricMN
Offline james_s
« Reply #4 on: April 28, 2020, 06:23:48 am »
You can find rackmount server fans that are quite powerful. I have some that I pulled from a scrapped Dell 2U server that draw something like 2.5A.
« Reply #5 on: April 29, 2020, 03:41:04 pm »
I haven't found an exact replacement but I've ordered a couple to try. I can get a new pump for $15 but it's not in stock anywhere so I have to wait until it is. In the mean time I thought I'd take a stab at repairing the pump. I don't even know if the driver chip is the problem but they're cheap so it's worth trying.
Offline james_s
« Reply #6 on: April 29, 2020, 04:28:33 pm »
There isn't much else to go wrong, if the shaft spins freely and the coils don't smell burned then it's probably just the IC.
