Author Topic: VOLTCRAFT VC850 no measurement  (Read 878 times)
Offline beymaTopic starter
« on: December 08, 2017, 10:17:37 pm »
Hello
The meter is based on the FS9922-DMM4 system and a large number of 062C opamp, one AD737J and HEF4070.
The WARNING message keeps flashing all the time and displays only zero - no measurement. On the inputs after setting to OHMY there is a voltage of about 1.4V, that is, the system probably works from the input to the switch.
Due to the large amount of OPAMPs, I do not know how to do it, and it would be useful for me to get a grip on it, or someone who has already processed such a topic or meter.
I greet all readers and thank you for all the help.
Witam
Miernik zbudowany jest na uk?adzie FS9922-DMM4 oraz du?ej ilo?ci opamp 062C, jednego AD737J i HEF4070.
W mierniku ca?y czas miga napis WARNING oraz wy?wietla same zera - brak jakiegokolwiek pomiaru. Na wej?ciach po ustawieniu na OHMY jest napi?cie ok 1.4V czyli od wej?cia do prze??cznika uk?ad chyba dzia?a.
Ze wzgl?du na du?? ilo?? OPAMPów troszk? nie wiem jak si? za to zabra? i w?a?nie przyda? by mi si? schemat by to ogarn?? b?d? kogo? kto ju? przerabia? taki temat czy miernik.
Pozdrawiam wszystkich czytaj?cych i za wszelk? pomoc dzi?kuj?.
