Author Topic: Voltcraft VLP-2403 lab psu  (Read 4864 times)
Offline DanielwTopic starter
« on: August 17, 2016, 08:06:51 pm »
Hello!
I just bought one Voltcraft VLP-2403 psu (http://www.conrad.com/ce/en/product/511815) Its a Conrad branded PSU. Or maybe even their own manufacture.
I got the schematics for it and thought firstly I would share it to the world and why not here?
I also modified the schematics to match my version. The grayed out areas are not in my PSU.
My questions are, Mod 1 and 2 any guesses why they are added?
And second question, on small loads and if CC get triggered - I get negative ~0.1v, havn't killed anything but annoying..
Any looking at the schematics, see anything that you would modify? :)
//Daniel
Offline Kleinstein
Re: Voltcraft VLP-2403 lab psu
« Reply #1 on: August 18, 2016, 05:13:20 pm »
The two extra diodes are likely to improve crossover from CC to CV mode and for protextion of the OP. It depends on the OP type of these diodes are needed or make sense. Usually the diodes should be anti - parallel, not in series.
The extra transistor helps a little to turn off the ouput stage a little faster. However this mainly makes sense if there is an additional diode / resitor from base to emitter at V3.
The part left out are for an analog meter - so not needed in the Version with digital display.
The current to provide the slghtly negative voltage, when current limit is set all the way to zero (or actually slighly negative) comes through R14. One way to fix this, could be adjusting the offset of the CC setting, so you can't set the current limit below about 1 mA. An alternative might be something to pull down the votlage at R14, if the ouput of OP4A is really high (e.g. > 2 V). However this might be a little tricky and should be simulated fist, as it could also effect (could be well be positive) the CC to CV transition and stability in CC mode.
The following users thanked this post: Danielw
« Reply #2 on: August 19, 2016, 11:01:29 am »
Thanks! I'll experiment some later! :)
I'll publish some more photos. The cabling isn't the most beautiful nor the soldering, but it works.. I've touched up some of the solder joints. I've also ordered 10w  r22 resistors instead of 5w, they get over 100c rather fast..
