Author Topic: Wall wart gone boom  (Read 2500 times)
Offline capt bullshotTopic starter
Wall wart gone boom
« on: October 18, 2017, 05:30:54 am »
So I've found this litte innocent 5V wall wart adaptor in the scrap box. Nosy as I am, I picked it and checked - nope, dead as a dodo.
Took it apart, et voila - there's been some arcing inside, you can see some blasted components and a clear trace of arcing from the gap underneath the transformer to some other trace. Distance bridged is 5mm. I wonder if some plasma from the other blasted components ignited this arc?
« Last Edit: October 18, 2017, 05:34:31 am by capt bullshot »
Offline Zucca
  • EE meid in Itali
Re: Wall wart gone boom
« Reply #1 on: October 18, 2017, 02:09:32 pm »
walking plasma wave? I mean fist arc, then the sencod and then the third until the complete board is toasted?
Ah, you don't want to repair that board, it makes no sense to me.
Online wraper
  • Country: lv
« Reply #2 on: October 18, 2017, 02:22:07 pm »
It think it's just magic smoke which escaped from resistor and deposited on PCB. No actual arching. Or if it was, then there should've been some water on the PCB when this happened.
« Reply #3 on: October 18, 2017, 02:42:24 pm »
There must have been an arc from the resistor (R26 or maybe 28) to the trace near the gap. You can see the burn marks at the end of the track. Some of the evidence looks like copper or tin deposited, yes that's true.
And no, I don't want to repair this thing.
Offline schmitt trigger
  • Country: mx
« Reply #4 on: October 18, 2017, 03:27:53 pm »
It is indeed a wide distance.
My theory would be that there was ionic contamination left over on the board (due to improper washing) and a dendrite or two which caused the flashover.
That theory would have to be validated though, with surface contamination testing.
Anyways, it appears that it arced between the primary (hot) and secondary. I'm glad that this accident did not happen to you while holding the phone, or whatever device was being powered up at the time.
Online wraper
  • Country: lv
« Reply #5 on: October 18, 2017, 07:44:05 pm »
I don't see any trace of damage on secondary side.
« Reply #6 on: October 19, 2017, 06:48:25 am »
I've taken a close-up of the damages and a view of a good one (that is broken in some other way :-)
From the good one, R26 is the current sense resistor in the emitter line of the main switching transistor. The transistor is shorted B-C-E, so my guess is:
Some kind of unknown event took out the main transistor, this let the magic smoke out of R26 and did some more collateral damage (the controller IC lost a leg and vented through a pinhole, some other resistors are blast and one more transistor lifted its hat).
IMO the R26 event started the arc to the 5mm distant PCB trace.
No, the secondary side was not hit by the arc, there's no visible evidence.
« Last Edit: October 19, 2017, 06:54:50 am by capt bullshot »
Offline jahonen
« Reply #7 on: October 19, 2017, 08:41:42 am »
My guess is that some line transient/surge event ignited the arc (to R28?) and caused the destruction of the rest of the circuit, as there is evidence of the arc going from line input to the internals of the circuit. I don't see how it otherwise could have happened.
Regards,
Janne
« Reply #8 on: October 19, 2017, 04:21:15 pm »
... I mean fist arc, then ...
I realize that's just a typo, but the image of a "fist arc" punching components to death is irresistible.
