I don't have a direct answer about who sells parts for these, but I will relate what I did with my SPM-19.
When received, it wouldn't power up, so I pulled out the power supply and disassembled it. What I found was that one or two of the main filter caps in the switching supply had spewed their guts. It wasn't a little fluid or crusty powder like one sees with small electrolytics, but rather a lot of thick oil was sprayed all over the components. Moreover, it must have sat for a while in this condition, and the oil was caustic, because it ate through a lot of the wire insulation - and the wiring was pretty pervasive throughout the supply.
I managed to replace the caps and clean it up as best as I could and the SPM-19 ran fine for a few weeks before the power supply died again.
This time, I junked the power supply and replaced it with a Meanwell RQ-125 switching supply. I had to add a 7806 6V regulator, a transistor switch, a relay and a battery holder (2xAA). In fact, it was good that I now just opened the unit up to take a photo, because clearly the batteries have leaked and need to be replaced!
Other than the power supply, over the years I have had a few logic chips go bad and one tantalum capacitor that exploded.
