Obviously there is an overcurrent somewhere. First, replace the fuse and then measure the current through it. If it's safe, then you have an intermittent problem. If it's marginally close to rating, then you need to find out why.
The problem is likely in one of two places. The power supply or one of the output amplifiers. Once you decide which, it should tell you where to look.
