Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Water Pressure Pump Switch contact damage
« previous
next »
Print
Search
Pages:
Prev
1
2
All
Go Down
Author
Topic: Water Pressure Pump Switch contact damage (Read 11101 times)
radioFlash
Regular Contributor
Country:
Re: Water Pressure Pump Switch contact damage
Reply #25 on:
December 29, 2019, 08:36:31 pm »
I'm going to go ahead and rewire the well shed with a proper sub-panel and grounding and reconfigure the pump to 240V. I'll look into installing RC snubbers and contactors. Thanks all for the suggestions.
Logged
radioFlash
Regular Contributor
Country:
Reply #26 on:
December 31, 2019, 01:52:06 am »
I replaced the old wiring with a subpanel and the pressure pump was rewired for 240V. It now draws 10 A in operation and there is much less arcing when it switches on.
Logged
SeanB
tooki
floobydust
floobydust
Super Contributor
Country:
Reply #27 on:
December 31, 2019, 04:54:04 am »
Ahhh much better
You might consider stuffing a MOV or snubber across the motor(s) terminals in one of the metal boxes, if the arcing is too much or radio interference etc. in a problem. Something that starts to clamp above say 275VRMS/350VDC like
MOV-20D431K
is small at 20mm.
Logged
Print
Search
Pages:
Prev
1
2
All
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
