Author Topic: WATTMETER IeS ISW8000  (Read 6110 times)
Offline lionelkjhTopic starter
« on: October 10, 2023, 01:06:40 pm »
Hello everyone! I am looking for the contents of the PIC16C55-RC/SP microprocessor mounted on an IeS isw8000 tabletop power meter located on the front panel (photo); (its marker is: U1)... Does anyone have it?? Thank you in advance for your research...Wouldn't there be a correspondence with POWERTEK??? :-// :-//
« Last Edit: October 10, 2023, 02:27:27 pm by lionelkjh »
Re: WATTMETER IeS ISW8000
« Reply #1 on: October 10, 2023, 02:40:45 pm »
Offline picburner
« Reply #2 on: October 11, 2023, 05:32:43 am »
I have a working IeS ISW8000. However, I noticed that the PIC16C55-RC/SP IC has the "Code Protect" function.
If they have programmed these bits, reading the code is almost impossible.
« Reply #3 on: October 11, 2023, 06:15:03 am »
Good morning; I would love to bring it to life, what would be the solution to reading it? :palm: :palm: :palm:
Offline picburner
« Reply #4 on: October 11, 2023, 06:56:02 am »
I tried to disassemble the IC in question but it is soldered directly onto the PCB and, to complicate things,
the front panel is soldered directly to the main PCB also.
To remove this IC it is necessary to completely disassemble the instrument.
« Reply #5 on: October 11, 2023, 10:49:10 am »
Hello again; a huge thank you if you manage to read the file and put it online!!! Thank you for your dedication! Dedicated people are rare these days....Cdt :-+ :-+ :-+
« Reply #6 on: October 11, 2023, 10:55:38 am »
Is the file sent that of the contents of the µPC? We display “NO FOUND”?? :-//
Offline picburner
« Reply #7 on: October 11, 2023, 11:12:48 am »
No, no, that attachment is a picture of the inside of my instrument. It is not the code file contained in the micro.
I don't know why the image can't be seen anymore. This morning it was perfectly visible.
However, as I told you previously, the chances of it being able to read the contents of the micro are slim. Most likely it is read protected.
In any case, since the micro is not on a socket, I can't tell you if and when I can do a similar job because it requires a lot of time which I don't have now.
« Last Edit: October 11, 2023, 11:15:30 am by picburner »
« Reply #8 on: October 11, 2023, 11:35:46 am »
D; ok, I understand... Do what you can; we have all our worries and concerns, it's already not bad to have taken an interest in my problem...Cdt ;)
« Reply #9 on: October 12, 2023, 04:41:26 pm »
Good morning; the photo appears well today....Indeed, it is the front of the wattmeter with the PIC..... :-+
« Reply #10 on: October 15, 2023, 08:49:34 am »
Good morning; Does anyone have a diagram of this device? Thanks for your help! :-//
Offline picburner
« Reply #11 on: October 15, 2023, 06:29:52 pm »
The schematics cannot be found online, only the user manual and the program for remote management.
Have you tried asking the manufacturer? It appears that the company still exists today.
When I purchased the instrument I made the dump of the at27c256 otp eprom and the 93c46 eeprom, I attach the file here in case you need it.
What fault does your isw8000 have?
« Reply #12 on: October 16, 2023, 03:43:13 pm »
Good evening; the buttons on the front panel do not react and the device remains stuck on a function; the alphanumeric display works well, the buttons have been checked and are good, as are the tracks and solders... I therefore strongly suspect the PIC of being the fault; but I need its contents...I don't think that the Eprom 27C and the EEprom 93C are the cause of the problem; because I do not have a frozen display nor the lost calibration constants..... I thank you in advance for taking an interest in my problem :-+ :-+
Offline picburner
« Reply #13 on: October 16, 2023, 04:31:55 pm »
Today I had a moment of time and I extracted IC1, the PIC16C55.
I took this opportunity to insert a socket.
As you can see from the my programmer's screen the result is what I told you previously:
the micro is read protected and there are only zeros in the resulting file.
« Reply #14 on: October 16, 2023, 04:49:28 pm »
D; I suspected it too, with some, you can read, and with others, you can't even with a simple PIC..... So according to you, it's ruined :scared:
Offline picburner
« Reply #15 on: October 16, 2023, 04:52:24 pm »
I just did a quick look only, but it seems to me that the scanning of the keys is done by the 80C32 micro by one of the two 74HC595 and not by the PIC16C55 micro, it only takes care of driving the display and the LEDs on the front panel.
« Reply #16 on: October 16, 2023, 05:03:25 pm »
The 74HC595 logic circuits have been tested and are ok... I don't believe that the 80C32 is guilty, because nothing seems fixed... The PIC microcontroller must be guilty; but I don't have a schema, and worse, I have no way of having its content to reprogram another one....
Offline picburner
« Reply #17 on: October 16, 2023, 05:10:48 pm »
It doesn't cost anything to ask the manufacturer, they may even provide you with the schematics and/or the replacement micro.
In the worst case scenario they will tell you no.
« Reply #18 on: October 16, 2023, 05:13:18 pm »
So the manufacturers would have coded the PIC only for the alphanumeric control of the front panel? :-//
« Reply #19 on: October 16, 2023, 05:29:49 pm »
In addition; It's old hardware, and I'm not convinced they still have the PIC program.... |O |O
Offline picburner
« Reply #20 on: October 16, 2023, 06:29:50 pm »
Despite all the torture I did to it today my instrument still works...
« Reply #21 on: October 17, 2023, 06:10:24 am »
Good morning; I tried this morning without the PIC and the wattmeter does not start, no relay switches: which proves that the PIC is the conductor and that it does not only manage the display.... .
Offline picburner
« Reply #22 on: October 17, 2023, 07:23:47 am »
In this case the situation is tragic: you need a replacement IC already programmed.
No one can give you its firmware only, I don't think even the manufacturer.
Or recover another broken instrument but with the PIC16C55 intact.
« Reply #23 on: October 18, 2023, 02:07:11 pm »
Good morning; I tried to contact the mother house this afternoon; without success, because the website in France is still active, but the number is no longer assigned. By doing in-depth research, the company was in receivership in 2017; so they closed! Is there a way to get a technical hotline in Europe? Thanks for your feedback :-[ :-[ :-[
« Reply #24 on: October 21, 2023, 08:41:16 am »
 :scared: :scared: :scared:
