Hi!
I got my hands on an old
WaveTek model 20 2MHz function generator. The schematics are available:
http://bama.edebris.com/manuals/wavetek/20/My unit works, but at higher frequencies there is some attenuation for all three waveforms (sin, triangle, and square). At 200 KHz and below the amplitude is the same, but as the frequency increases, the amplitude goes down. At 2MHz the amplitude is about half of what I have at 200 KHz. This attenuation happens at all amplitude settings, so 20V p-p goes down to 10V p-p and 4V p-p goes down to 2V p-p.
I'm using a 10MHz scope with a 10MOhm/40pF input. The manual suggests to terminate the cable with a 600 Ohm resistor, and I'm not doing that (can't do that easily, the scope uses an unusual connector and its pins are not exposed).
Is this the expected behavior of this generator?
