Hello. Been lurking this forum for quite some time and just wanna say it's a great forum.
I have a small problem, maybe someone could point me in the right direction. I'm a newbie at electronics but have a somewhat grasp of fundamentals. (I think
I have a Mammography unit that has up/down movement provided by a motor. When I press the UP button the motor pulls the c-arm up, even if I apply some downward pressure. When I press the DOWN button it will move for a quick sec then stop, if I help it by applying downward force then the motor can pull down.
At first I thought it was a bad motor, so I ordered a new one, but I get the same problem with the new motor. I thought it might be the rails where the c-arm travels but I can easily move it up/down when the motor is disengaged.
So I hooked up the motor without mounting it in the machine and when pressing the UP button the motor will turn even if I try holding the rotation with my hands, but when pressing the DOWN button the motor will stop when I apply medium force to stop the rotation. I also hooked up a multi-meter while pressing DOWN and while preventing it to rotate and what happens is that the voltage rises then it goes to zero. It seems like the circuit is sensing that the motor stalling but it's too sensitive.
Unfortunately these machines do not come with circuit schematics only block diagrams, so I'm wondering if someone could explain what component arrangement could be used to sense the motor stall.
Thanks
