after lurking this meter for years (have a BK Precision 878 and did'nt really need it) I finally took the plunge and bought it
I received my unit 4 days ago and yesterday it failed showing exactly the same symptoms as dfmischler's (thanks for your post and for the schematics)
And yes , it looks like the culprit is Q14, a smd P-channel Mosfet
Turned out is not shorted, it is rather leaking, preventing its Drain to go to zero volt, so that the system is not getting the correct Power ON Reset and the meter does not turn on
Since I was not seing any short between pins and the diode inside tested good, initially I was not convinced the culprit was Q14
So, while the meter was supplied with 9V from Lab Power Supply, I forced Q14 Drain to go down ( a 10 ohm resistor between Q14 Drain and ground), and bingo: pressing the power button the meter came alive !
Now waiting for a spare Q14 (SI2301) to arrive
adri
