Electronics => Repair => Topic started by: staze on July 18, 2019, 01:59:28 am
Hi All,
I'm trying to find a replacement relay (General Purpose) that's 250v 10a switching, with a 24v coil. But the pin pitch is weird. Standard GP relays seem to all be 12.2mm by 12mm pin pitch for the main 4 pins (the 5th is offset).
This device is from the early 90's and rather than 12.2mm, the pitch is 15mm.
Anyone have any ideas?
