Hello everyone! I'm fairly new to the oscilloscope, and when troubleshooting, I poked my oscilloscope at both terminals of an inductor 220, as shown in the picture:
The bottom terminal of the inductor is connected via U2 at pin 6 and 5, which is SW (Switch Pin. Connect external inductor/diode here) and continues on to the D1 diode, and going downwards C2, CT3, CT4 as so on.
With my multimeter, both terminals of the inductor shows 5volts. However, when using my oscilloscope, I'm getting very different results.
First picture is from the upper terminal in the photo, and the last picture is from the bottom terminal connected via the U2 SW pins. It looks very messy and I don't know why.
This device is supposed to be attached to a hard drive so you can use it as an external hard drive. However, it fails to start the hard drive properly. What happens is that the hard drive starts spinning (and the amp usage goes up) and after a second, it stops spinning and goes down to a lower amp usage. So basically, you can hear the hard drive start spinning (but not as much as when I plug it into another adapter).. It seems to fail before it gets up in working conditions, so it's not completely dead, it just fails to drive the hard drive.
