So I was cleaning a HP 8350B mainframe, I fixed the problem, washed it out, dried it *usually im successful with this*, tested it last night (and it was broken, giving me e15) and today I had another look and I found some kind of weird 'blob' of fluffy highly electrically conductive stuff on one of the screws near the PCB. No clue what it is. I extracted it with a pair of tweezers, but it falls apart easily.
It's kind of like if you drop solder on ceramic while its molten and it makes a thin sheet, but imagine this stuff is about 1 thousandth thick, usually when you drip solder its fairly thick. This reminds me of gold leaf but silver colored. Like if you took gold leaf and crumpled it up good, or similar to the material on the inside of bubble gum wrappers.
Now all I really did on the main board that I found this on is pour a little dilute simple green on it, scrub around with a bamboo brush gently and then rinse off with water for a good while then DI water then light air compressor then thermocouple controlled bake for a while. I found this stuff 'accumulated' on one of the screws that screw an aluminum bracket on the main board.
Now I can't describe this any other way then really thin really fragile conductive foil material (probes to 0.1 ohm when stabbed with dmm). I found a 'blob' of this shit that is around 1cm in diameter near the power supply section.
I tried to photo it.
WTF is this? I never saw something similar in a meter, and I don't have any thin foils or anything like that. I never seen solder spatter so thin. I literary did nothing but slight agitation and water spraying. It looks like if you spread it out, it would be a high surface area thin foil.
