Hello scope afficionados...
I recently stripped my Tek DPO3052 scope to replace the LCD backlight. Put it back together, but now the screen just turns black upon powerup.
It does power up and the fan runs and some green led's on the main board light up, but the front panel keys do nothing.
I have since taken it apart numerous times to check all the plugs and wiring, tested the DC power supply and even tried an external monitor. ...Nothing... I'm at a dead end here. I can only conclude that I somehow damaged the main board during teardown, but there are no visible damage or clues...
As you know, Tek doesn't provide circuit diagrams or even block diagrams.
Any ideas and help will be much appreciated.
