Pump is working, but heater wont come on no matter the temperature knob setting.
I've dissambled the cable connector for the pen, and was surprised to find only 3 wires going to the pen. Two black wires, apparently for a 5 ohm heating element, a white wire for chassis. Also there is a small PCB inside the connector (see reverse engineered schematic). Adjusting the potmeter makes no difference.
Interestingly, I am able to make the lamp come on (albeit dim) by connecting a 1K - 5K6 resistor over pin 3+4
- Has anyone experience with this device?
- Is it even worth bothering with a solder station without a proper temperature sensor? I wonder how the regulation is done.
