Electronics => Repair => Topic started by: hoei on May 07, 2020, 09:52:40 am
Pump is working, but heater wont come on no matter the temperature knob setting.
I've dissambled the cable connector for the pen, and was surprised to find only 3 wires going to the pen. Two black wires, apparently for a 5 ohm heating element, a white wire for chassis. Also there is a small PCB inside the connector (see reverse engineered schematic). Adjusting the potmeter makes no difference.
Interestingly, I am able to make the lamp come on (albeit dim) by connecting a 1K - 5K6 resistor over pin 3+4
- Has anyone experience with this device?
- Is it even worth bothering with a solder station without a proper temperature sensor? I wonder how the regulation is done.
Ok, so took the case apart and found out that the temperature control pot is not getting any supply voltage at all. It is connected to a transistor T1 (only TO-92 on the board) which seem to be a darlington. Marking is "bl" , "C617".
Anyway, I didn't get much further because suddenly the 8V dc supply blew up, so now I have to replace one of the bridge diodes and the 8V regulator L7808CV.
