Author Topic: Orolia / Spectracom NetClock 9483 - GPS Time Server repair  (Read 596 times)
Offline OmnTopic starter
« on: September 18, 2022, 12:16:21 pm »
I stumbled upon a faulty Spectracom NetClock 9483 recently that I've just started to troubleshoot.
The u-blox M8T GPS module checked out, as did the internal battery & memory module etc. I tried the serial port but wasn't getting anything out of it.
I haven't come across this before in an appliance but socketed in the main mainboard is a SOM-4455 - System On Module - containing an AMD CPU, memory socket and a bunch of IO interfaces.
I spotted what looked to be a VGA connector on the mainboard near the SOM module and plugged in a monitor just for fun - here's the result:
Quite cool to get a picture up on the screen. I tested the CF card externally, and sure enough - it was stuffed.
I plugged a keyboard in to the USB port on the back of the appliance and was able to use it to get into the BIOS as well:
I read a few of @SoundTech-LG's posts about these units and reached out for help and they found the internal VGA connectivity quite interesting like I did and worth a post :)
Offline SoundTech-LG
Re: Orolia / Spectracom NetClock 9483 - GPS Time Server repair
« Reply #1 on: September 18, 2022, 05:40:10 pm »
Hi, yes the mini computer module (SOM) does have that VGA connector on it. Thought you were referring to a connector on the outer case. Trying to remember if I hooked it up before. The Display results look familiar. Either way it is very good to know.
If the serial port was working it's possible you could see interactions on the CLI (command line interface). Not sure if the serial port should work with no CF card installed.
