Hey, I am not good at academic type reply but ask you, when you open up electronic equipment, you find isolated transformer inside or wraper Auto-Trans inside?
Common Sense question. Auto-trans is cheaper but?
You think symetrically but in reality the load is single ended where I2 is part of I1 and the other half is I1-I2, so in practice it is not symetrical static type balance analogy. The induction in one is not the same as the other. The transients are not the same dynamically.
The point is isolated transformer is VA limited and Auto-Trans is Grid KVA limited.
If you mistaken the point, please read #51. But if you are still not satisfied, please derive your proof of academic formulation and scientific derivations so that others can appreciate your logic.
Ok busy, subject ends for me. thanks.
busy...bye.
Armadillo, consider connecting the primaries of two 110V transformers in series and then connecting the top and the bottom terminals to a 220V outlet. Do you really think you will have 220V in the middle terminal as well?
