Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Weller WHA-300 repair
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Weller WHA-300 repair (Read 633 times)
pienari
Regular Contributor
Country:
on:
October 07, 2024, 09:28:33 pm »
I have looked schematics for the WHA-300 but not found.
Heater works.
Fan is dead.
I tested fan motor with external ac psu and it works fine.
Anyone have this hot air station?
Logged
pienari
Regular Contributor
Country:
Re: Weller WHA-300 repair
Reply #1 on:
October 08, 2024, 01:54:38 pm »
I have tested all diodes and transistors ok.
I replaced all ic.
2pcs thyristors are ok.
To do list.
SMD resistor values ??
SMD capacitors ??
Logged
Andy Watson
Super Contributor
Reply #2 on:
October 08, 2024, 05:55:28 pm »
Quote from: pienari on October 08, 2024, 01:54:38 pm
I replaced all ic.
What types of chip? Are any of them microcontrollers?
Logged
Bryn
Regular Contributor
Country:
Reply #3 on:
October 08, 2024, 06:02:49 pm »
Regarding the capacitors, make sure they're not damaged.
Have you checked the power supply of the fan also? That could be an issue also, if it's not receiving much power from it.
Logged
pienari
Regular Contributor
Country:
Reply #4 on:
October 08, 2024, 07:12:19 pm »
I have to get board powered and make some measurements.
There is no microcontrollers.
Fuses are ok.
Optocouplers i need to remove from board and test.
Logged
pienari
Regular Contributor
Country:
Reply #5 on:
October 08, 2024, 07:13:36 pm »
1 more
Logged
pienari
Regular Contributor
Country:
Reply #6 on:
October 10, 2024, 12:27:52 pm »
Both optocouplers are good.
Logged
pienari
Regular Contributor
Country:
Reply #7 on:
October 13, 2024, 01:29:57 pm »
I manage to get it partially workking now.
Now power on fan spins all time really slow ,
When button is pushed fan spins faster ,rpm can be adjusted, led blinks and heater temp adjust works fine.
Needs more inspection.
Last Edit: October 13, 2024, 02:57:47 pm by pienari
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
