Author Topic: Weller WMD3 issue  (Read 469 times)
Offline Alban LGTopic starter
Weller WMD3 issue
« on: March 28, 2023, 07:09:41 am »
Hello everyone,
I just bought a used Weller WMD 3 and just received it.
The irons get hot, the vacuum is a bit capricious and the AIR doesn't work at all. So I have this faulty AIR/VACUUM pump.
The second problem is that the UP and DOWN keys doesn't work. I tried a RESET by pressing the TIMER and "1,2,3" buttons, the screen displays "000" but the factory settings are not restored.
I wondered if I have dead switch but they work when I hold down the "1,2,3" button while scrolling through the channels.
I'm thinking an EEPROM problem...
What else can I check?
Offline m k
Re: Weller WMD3 issue
« Reply #1 on: April 01, 2023, 04:20:51 pm »
Can you check the pump with external power?
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
