Hi all!
This Ambarella A7 Mini 0805 dashcam has a blown SMD component, probably a SOT23-5 voltage regulator (dimensions: 1.7mm x 3.0mm). With a loupe I can read markings BQ:R0.. which (I guess) is identical with another component at the other end of the board, BQ:R02, and two other SMDs on the black PCB, U3 and U12. When you connect 5V power the main A7 chip gets very hot and no sign of life. Prior to this fault the dashcam was having issues with battery charging. I don't want to waste a lot of money on this, but maybe a few dollars on an ebay SOT-23-5 listings. What should I look for? A 3.3V or 5V voltage regulator?
Attaching the photos of the boards, the blown component is in the first photo, on the right-top edge. Same component can be seen at left middle edge on the same board and as U3 and U12 on the black sensor/input board.
Thanks for any help.
