Author Topic: W&G sna-20/23 spectrum analyzer repair  (Read 14079 times)
Offline aseokTopic starter
« on: September 30, 2019, 06:23:15 am »
Hi.
I have a sna-20 and sna-23 spectrum analyzers from wandel & goltermann, both facing problems and need repair.
sna-20 has hard drive controller failure error.
sna-23 has problem of sending incorrect lcd data and hdd related problem.
both have compensation data floppy disks but problem doesn't solve by running compensation software.
Has anyone experience of repairing these systems?
« Last Edit: November 30, 2019, 07:56:06 am by aseok »
Re: W&G sna-20/23 spectrum analyzer repair
« Reply #1 on: November 29, 2019, 11:50:30 am »
After inspecting for a couple of days and replacing some parts, it seems that i need installation firmware of these SAs, say, SNA-20 and SNA-23.
Does anyone have the related firmware/floppy disks?
Thanks.
Offline kyndbo
« Reply #2 on: December 29, 2019, 06:18:32 pm »
HI aseok,
Can I get a copy of your  compensation data floppy disks ?
I have a SNA 23 , but no boot disk, I have changed backup battery, but would like to try to boot from floppy disk,
to restore my data in B: drive ,
I woud like to share our findings with our analyzers, and solve them,
regards helge
kyndbo@gmail.com
« Reply #3 on: December 30, 2019, 04:55:40 am »
As you know, all floppy data sectors must be copied and pasted in a floppy to work.
What is the hard drive of sna 23? does it boot from cf card?
Offline Qw3rtzuiop
« Reply #4 on: October 26, 2020, 07:20:27 pm »
Hello guys,
were you able to repair your analyzers?
Ive repaired one of these lately and uploaded photos and the hdd backup to xdevs.com.
But my SNA23 is from the H series without the ram. Just one HDD.
All the stuff is here:
https://xdevs.com/doc/WG/SNA23/
Offline Gerhard_dk4xp
« Reply #5 on: October 26, 2020, 10:51:19 pm »
I have a SNA-33 that has a floppy and a battery-powered ramdisk. It still
boots, but I was thinking that I had destroyed the input. Seems not to be
the case, but it is still completely deaf. I must look into this soon now,  :-[
Gerhard
Offline Qw3rtzuiop
« Reply #6 on: October 27, 2020, 09:52:30 am »
Seems not to be
My unit was also completly deaf. The trace was visible but no signals. The error was the missing -6.8V power supply rail. There was a broken diode in the power supply. After changing the diode the unit worked flawless again
« Reply #7 on: November 17, 2020, 02:39:24 pm »
Hi
Would you please send a picture including HDD attached in place? my sna23 is missing hdd and i thought that the compact flash is the main memory.
Thanks.
Offline Qw3rtzuiop
« Reply #8 on: November 17, 2020, 05:01:08 pm »
There is an HDD image here:
https://xdevs.com/doc/WG/SNA23/hdd%20backup/
You can burn it with HDD Raw Copy Tool
« Reply #9 on: November 17, 2020, 05:50:26 pm »
my sna23 is f series, is it compatible with your image?
« Reply #10 on: November 17, 2020, 06:38:15 pm »
Is it the hdd connector? another point is that i have a 60GB hdd, can i use that?
« Last Edit: November 17, 2020, 06:41:04 pm by aseok »
Offline Qw3rtzuiop
« Reply #11 on: November 17, 2020, 09:05:07 pm »
Yes that is the IDE connector. I dont know if the image will workfor you but there are good chances. But a 60gb HDD will not work.
I noticed that just 512mb are working correctly. There is a limit defined by the bios. I installed a CF Card to IDE adapter with a 512 MB card.
The following users thanked this post: lscw
« Reply #12 on: November 18, 2020, 08:59:54 am »
What does cf card do beside hdd? is it necessary?
« Reply #13 on: November 18, 2020, 06:17:20 pm »
As the connector is 50 pin, how should 40 pin ide connect to it?
« Reply #14 on: November 18, 2020, 06:26:37 pm »
Maybe SCSI???
Offline Qw3rtzuiop
« Reply #15 on: November 18, 2020, 07:08:49 pm »
It is IDE. The spare pins are not connected or connected to the hdd jumpers.
« Reply #16 on: November 19, 2020, 07:42:09 am »
Seems not to be
Would you please send a video of your sna from booting up to main software start?
Thanks.
Offline Qw3rtzuiop
« Reply #17 on: November 19, 2020, 08:52:38 am »
Here is the a video of the start up:
https://youtu.be/-rusvtIUkgI
Offline NIKGEROS
  • Country: gr
« Reply #18 on: November 19, 2020, 11:14:17 am »
Hello everybody,
in case somebody could advise : I have a SNA-23 and facing BOOT problem. I use the disk but when the process is finished it keeps looping again asking for the disk.
thanks a lot,
Nikos
« Reply #19 on: November 19, 2020, 01:07:13 pm »
does 40 pin ide connect at the middle of 50 pin connector, symmetrically?
« Reply #20 on: November 19, 2020, 01:09:38 pm »
Hello everybody,
thanks a lot,
Nikos
Hello
What is the version of your sna? what is main memory?
Offline Qw3rtzuiop
« Reply #21 on: November 19, 2020, 06:14:44 pm »
No. Take a look at that picture i posted. You need to connect it at the 44 pin side. Just leave the 4 power supply pins empty. The 4 power supply pins are on the left side.
« Last Edit: November 19, 2020, 06:17:08 pm by Qw3rtzuiop »
« Reply #22 on: November 20, 2020, 06:00:06 am »
HI aseok,
regards helge
kyndbo@gmail.com
Hi kyndbo
Which version is your sna? does it have dram module?
« Reply #23 on: November 20, 2020, 08:44:00 am »
which pins are 1 and 44?
« Reply #24 on: November 24, 2020, 11:16:49 am »
There is a project RASCSI that uses raspberry pi as scsi hard disk emulator and is originally written and tested for sharp x68000 & mac pcs. i wonder if we can use it with our SNAs.
https://github.com/akuker/RASCSI
