Author Topic: What can I use to programme a dsPIC33F?  (Read 759 times)
Online perdrixTopic starter
« on: May 22, 2020, 01:08:30 pm »
A telescope mount controller I have to repair drives the motor H-Bridge using a programmed DSPIC33FJ12MC201 IC.
So far so good - but one of them has gone bad :(
If I can pry the firmware image out of the supplier - what can I use to programme these babies - neither my Galep-4, nor my Dataman 48XP recognise that the DSPIC33 exists :(
There's a fix pin socket (0.1" pitch I think) right next to the IC which is clearly intended for programming it with pin 1 to Vpp, 2 to Vcc, 3 to Gnd, 4 to PGD, and 5 to PGC I htinkn these are referred to as PIC ICSP MINI 5 PIN sockets.
Thanks
Online jpanhalt
Re: What can I use to programme a dsPIC33F?
« Reply #1 on: May 22, 2020, 01:25:38 pm »
Most of the Microchip programmers can program and debug that chip:
Of course later versions of the same devices can too, like PK4 and ICD4.
Online oPossum
« Last Edit: May 22, 2020, 01:29:04 pm by oPossum »
« Reply #3 on: May 22, 2020, 01:42:24 pm »
Looks like the PicKit4 is what I need.  That ICD4 is a touch too spendy!
Thanks
Offline NivagSwerdna
« Reply #4 on: May 22, 2020, 02:06:06 pm »
^ SNAP
« Reply #5 on: May 22, 2020, 02:15:36 pm »
Compatibility chart from MPLABX
