Author Topic: What Defects Can Affect An IC?  (Read 797 times)
Offline FPTECTopic starter
  • Country: br
« on: June 30, 2017, 03:55:06 am »
Hello,
What defects can affect an IC?
I have had a bit of trouble making sure a BGA CI is defective.
I know it depends on the IC, but roughly, which tests do you recommend?
Thank you.
Offline rs20
Re: What Defects Can Affect An IC?
« Reply #1 on: June 30, 2017, 06:24:44 am »
Looks at the IC's datasheet. Check that all of the facts stated in the datasheet are true of the IC in front of you.
For example, if it's an op-amp, check that is amplifies. If it's a microcontroller, check that it communicates over JTAG and computes. You'll have to be much more specific about the IC you have before we can provide any remotely applicable advice, I suspect.
