Author Topic: what IC is that ? Dwa108-A  (Read 7212 times)
Offline boo9Topic starter
« on: May 06, 2016, 10:20:54 pm »
Could somone please help me identify following element from ATX power supply, Delta DPS-280FB
May be the IC has different more popular designation ?
I cannot locate datasheets or schematics :(
Hint: There is a LM339n (quad comparator)  next to this chip on the PCB.
« Last Edit: May 07, 2016, 08:19:24 am by boo9 »
Offline amyk
Re: what IC is that ? Dwa108-A
« Reply #1 on: May 07, 2016, 02:35:32 pm »
Delta used proprietary controllers in their PSUs. Trace out the circuit and see if that gives you any clues if it's similar to some other common one.
The following users thanked this post: boo9
Offline gamalot
  • Correct my English
    • Youtube
« Reply #2 on: May 07, 2016, 03:41:41 pm »
I am not 100% sure, it may be compatible with TPS5510, hope this help  :)
http://www.ti.com/lit/ds/symlink/tps5510.pdf
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
« Reply #3 on: May 07, 2016, 09:42:36 pm »
thank you very much, guys
EDIT: the measured voltages on the pins of the IC match the  TPS5510 specs.
many thanks.
« Last Edit: May 08, 2016, 01:12:35 pm by boo9 »
