Author Topic: What is an FTZ Coil?  (Read 3256 times)
Offline HextejasTopic starter
« on: September 08, 2018, 06:18:24 pm »
I am repairing Nad 402 AM/FM tuner and I want to replace this part. Trouble is I can't find it.
It has the following info:
From the manual:
Part number N56002296-S   Coil FTZ   Filter 10DFE01
From the part
Sumida 10DF  E01  S443  H023
Any ideas ?
Well, I am going to give this up for awhile. I cant figure out what's wrong and dont want to spend another frustrating minute on it until after i do another project or 2 with more of a chance of success.
Thanks again for all the help.
« Last Edit: September 10, 2018, 08:49:22 pm by Hextejas »
Online PA0PBZ
Re: What is an FTZ Coil?
« Reply #1 on: September 08, 2018, 06:26:28 pm »
Online Gyro
« Reply #2 on: September 08, 2018, 06:35:41 pm »
Picture?
It might just be short for filter. Hard to say without seeing it.
Best Regards, Chris
Offline Terry01
  • Country: scotland
« Reply #3 on: September 08, 2018, 06:41:57 pm »
From the manual:
From the part
Any ideas
A decent photo is usually a great help. I don't know what the part is buddy but i have seen the guys here identifying loads of things just from a photo. A good quality high def is really awesome help!  :)
Sparks and Smoke means i'm nearly there!
Online PA0PBZ
« Reply #4 on: September 08, 2018, 06:48:44 pm »
Sumida is the brand, 10DF says something about the housing (see pic), the rest I have no idea.
https://products.sumida.com/ProductsInfo/
Online Gyro
« Reply #5 on: September 08, 2018, 06:59:11 pm »
Ah, ok.
In that case it could be an IF transformer (coil is a pretty 'broad' term in a parts list), a local oscillator inductor or a filter.  Physical location might provide a clue.
Why do you want to replace it? It's not the sort of part that usually dies. As it's adjustable, you'd need to do some alignment after replacing it. I'd start by trying to figure out its pinout. as it will have have low resistance windings, you ought to be able to do it in-circuit if you're careful.
Best Regards, Chris
Online PA0PBZ
« Reply #6 on: September 08, 2018, 07:10:41 pm »
Physical location and the color of the adjust 'screw' can tell you which one it is, MW OSC is usually red, 10.7 IF orange etc. One reason I can see why it needs to be replaced is a bit too much adjusting where the ferrite breaks in half... been there, done that  :palm:
Online PA0PBZ
« Reply #7 on: September 08, 2018, 07:18:50 pm »
Interesting, in the schematic it looks like a dime-a-dozen ceramic 10.7 filter but on the pcb it looks like a IF coil.
So there goes my adjusting theory…  I'd go with ceramic filter anyway.
« Reply #8 on: September 08, 2018, 08:52:05 pm »
Ok, here's the picture. And the reason that I am thinking about replacing it is that for this tuner, I got the AM working but not the FM. So I was replacing all the capacitors in the signal path (as best as I can discern it), and this thing is also in the path.
Online Gyro
« Reply #9 on: September 08, 2018, 09:06:35 pm »
Ah ok, already out.
In that case, I'd check for continuity map out continuity of the pins against the PCB footprint. If it's a 10.7MHz filter then it's probably an LC configuration.
Bypassing in-out pads on the PCB might give some clue, otherwise try a 10.7MHz ceramic filter as PA0PBZ suggests (not sure how lossy they are in comparison).
[EDIT] Hang on, checking the IC datasheets, aren't we past the IF strip by now - that's all handled in the LA1266, the LA3401 is the AM / FM switching and stereo decode. I don't think FL5 is 10.7MHz.  Also leaky or reversed C56 would screw up the internal biassing of LA3401 pin 2. Worth a try.
[EDIT1] Have you checked that the AM/FM select pin (10) of the LA3401 is being driven correctly?
« Last Edit: September 08, 2018, 09:26:47 pm by Gyro »
Best Regards, Chris
Offline emece67
« Reply #10 on: September 08, 2018, 09:28:10 pm »
« Last Edit: August 19, 2022, 01:59:22 pm by emece67 »
Online Gyro
« Reply #11 on: September 08, 2018, 09:32:29 pm »
Hmm, whatever is going through FL5 is then going through a 10uF non-bypassed electrolytic, the frequency can't be that high.
Best Regards, Chris
Online Gyro
« Reply #12 on: September 09, 2018, 11:04:02 am »
I didn't realize this was part of https://www.eevblog.com/forum/repair/i-am-trying-to-fix-this-fm-tuner/
Please don't do that!  ::)
Best Regards, Chris
« Reply #13 on: September 09, 2018, 11:30:54 am »
Thank you Gyro, but I was just trying to make things easier on you good folks. The reason for a separate post is that
I didn't want to make you wade through all the "already fixed" issues I had with this tuner.
Just a simple parts identification question.
Maybe a mod could tell me if I did wrong.
73
Online Gyro
« Reply #14 on: September 09, 2018, 11:59:09 am »
Not so much a matter of 'doing wrong', more a matter of trying to work out what a part is in isolation, without datasheet and context.... followed by what does it look like, where does it fit in the circuit, oh, it's between these ICs, look up  the datasheets, followed by....
Time and effort and a bit of good will wasted. An in context reply in your other thread would have achieved an easier response from those already 'in the loop'.
[EDIT: Actually, I see now that it's your third thread on this tuner repair.... https://www.eevblog.com/forum/repair/is-this-feasible-and-i-apologize-for-the-vagueness/, so maybe veering much closer to the 'doing wrong'  :-\]
« Last Edit: September 09, 2018, 12:13:25 pm by Gyro »
Best Regards, Chris
Online PA0PBZ
« Reply #15 on: September 09, 2018, 12:59:03 pm »
Ah yes, it is audio, so it probably is some kind of low pass filter with a 40KHz cutoff.
« Reply #16 on: September 09, 2018, 01:41:49 pm »
It seems that I ruined the part while taking it out so I am going to wire a jumper in its place and see what happens.
The last time that I had the tuner plugged in and working with AM I took some voltage readings with these results.
LA3401
Pin 2 = 2.9V
I replaced capacitors C40 and C56
I had it tuned to 91.7FM, a local C&W station. There was another light on the panel that was on and it was "Center Tune".
« Reply #17 on: September 09, 2018, 01:47:28 pm »
One more thing is that I have an oscilloscope that I am testing and I was wondering where in the schematic I would put it in order to see the FM signal ?
thanks
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #18 on: September 09, 2018, 07:59:41 pm »
73
Having multiple threads about the same thing will lead to confusion and frustration. If it's a large topic and things change over time the best thing is to post updates on your initial opening post which you can do by editing the post.
The following users thanked this post: Hextejas
