So I'm having some problems with the horizontal sweep on my HP 1743A CRO. Intermittently I'm seeing two different anomalies:
In one, the beam just (correctly) traces up-and-down vertically, but stuck in the dead center of the CRT. The result is a vertical line, albeit of the correct length/V.
In the second, the trace is shaped correctly and does have some horizontal movement but all confined within the right-most 1/4 of the CRT.
Adjusting the horizontal position all of the way left pulls the trace toward (but never past) the center point.
The problem affects both A and B channels, so it would seem that the sweep generator is having some sort of problem. But it got me thinking:
if the sweep generator is "dead", where would the CRT gun end up pointing in the absence of deflection voltage: at the extreme left, extreme right, or dead center? I think this will help me better understand what is happening in the sweep generator.
As a side note: the problems can often be stopped by switching around various controls (time/div, V/div, channel, single/chop display, etc.) There's no apparent rhyme or reason to what changes will affect the behavior other than they "move things around". Also, now that I have the case off it seems less prone to having the problems - until they reappear. But cooling things down with compressed air didn't in and of itself help any. Hmmm...
