Author Topic: What is the easiest way to remove conformal coating from a PCB?  (Read 989 times)
Offline 4cx10000Topic starter
Hi!
A pcb with conformal coating, from a Husqvarna robot lawn mover, is now on my workbench. I have cleaned - well ... tried the best I could - coated boards before, but with poor to medium results. Wonder how you guys solve this and what would be the easiest way to go?
"Messen ist Wissen, aber messen ohne wissen ist kein wissen"
Offline chriva
Re: What is the easiest way to remove conformal coating from a PCB?
« Reply #1 on: May 26, 2020, 07:23:02 pm »
It depends on which type of coating but if it's acrylic or epoxy, Acetone usually does a decent job.
Method of removal is anything from a soaked toothbrush to just dunking the whole thing in a large container filled with acetone :)
The following users thanked this post: 4cx10000
« Reply #2 on: May 26, 2020, 07:37:33 pm »
Thanks chriva! :D
How would you describe the difference between acrylic and epoxy coated boards in softness? Guess that those with epoxy coating has harder surface compared to acrylic. My board is, I believe, coated with the latter because it can be peeled off quiet easily, but of course it leave residues and more cleaning is needed.
Offline BreakingOhmsLaw
  • Certified solder fume addict
« Reply #3 on: May 26, 2020, 08:03:16 pm »
Beware, acetone kills plastics fast. Test before going full speed
On a related note: google for "plunger can".  These are great.
Offline m3vuv
« Reply #4 on: May 26, 2020, 09:09:24 pm »
i would try some paint stripper.
