Author Topic: What is the exact model of this transistor?  (Read 4131 times)
Offline daisizhouTopic starter
  • Country: cn
« on: April 17, 2024, 03:12:32 pm »
Shell reads "MSPF 179 752"
Does anyone know its exact model?
If you know please tell me, thanks
daisizhou#sina.com #=@
Online wasedadoc
Re: What is the exact model of this transistor?
« Reply #1 on: April 17, 2024, 03:19:33 pm »
That 'M' is the Motorola logo.  Probably not the first letter of the model number.
SPF179 is a N-channel FET.
« Last Edit: April 17, 2024, 03:30:40 pm by wasedadoc »
The following users thanked this post: wraper, bdunham7
  • Country: cn
« Reply #2 on: April 17, 2024, 03:33:30 pm »
SPF 179 152?But there is no such model
Online bdunham7
« Reply #3 on: April 17, 2024, 03:33:35 pm »
It is a Motorola/Freescale SPF179 aka Fluke 261388, identified as NSN 5961-00-402-1979.  I've no idea what exact type of device it actually is and at least one source says that it is ITAR controlled.  I found no cross-reference to any jelly bean parts as you're probably hoping.  It might be a special or select version of the BF179, but I'd have to know what device it is in and how it is used to say whether that's even a possibility.
Online bdunham7
« Reply #4 on: April 17, 2024, 03:34:34 pm »
I didn't find it for some reason.  Where did you look that up?
Online wasedadoc
« Reply #5 on: April 17, 2024, 03:41:09 pm »
Occurs in some parts lists for old Fluke equipment.  E.g. bottom of page 5-20 of https://usermanual.wiki/m/3f0ec0ba0fdff036e359a258d61212986186bc5daca87076268a318ead250057.pdf and Q17, Q26 on page 5-13 of https://manualzz.com/doc/22683395/515a---fluke
« Last Edit: April 17, 2024, 03:46:58 pm by wasedadoc »
Online bdunham7
« Reply #6 on: April 17, 2024, 04:12:31 pm »
[/quote]
I didn't try looking in any of my manuals as I'm somewhat familiar with the N-J-Fets in the stuff I have.  I think one could write a whole book just on the custom/select N-J-Fets of Fluke.
Fortunately Central Semiconductor still makes J-FETs, the PN4391/4392/4393 series work in a lot of Fluke applications.
Offline BrokenYugo
« Reply #7 on: April 17, 2024, 04:32:13 pm »
152 is probably the date code.
Online wasedadoc
« Reply #8 on: April 17, 2024, 05:04:47 pm »
It is 752, not 152.  Date code or some other  batch, factory or other code.
  • Country: cn
« Reply #10 on: April 17, 2024, 08:32:47 pm »
Thanks.It comes from Fluke 8920a. Please see Q208, Q209 on page 117 of the accessory manual.(https://www.elso.sk/media/download/pdf/fluke/man/Fluke_8920A_8921A_Manual.pdf)
I removed the influence of S202, S203 and U205 on the circuit,Measure the resistance of Q209 and Q208 to be 68.4 ohms.
Q209 and Q208 are the transistors above,I don’t know if Q208 and Q209 are faulty or normal.
  • Country: cn
« Reply #11 on: April 18, 2024, 01:56:55 am »
Q208、Q209,Rds Is the resistance value 68.5-68.4 ohms normal?
Online bdunham7
« Reply #12 on: April 18, 2024, 02:04:53 am »
Probably normal, the J-FET conducts until it is turned off but is only intended for small power levels.  Without a datasheet it's hard to know precisely what a good value is but I'd expect something like that.  The PN4392 that I commonly use to replace some Fluke J-FETS has a max RDS(ON) of 60 ohms and the lower-leakage more sensitive PN4393 is 100 ohms.  You should check the gate leakage as well.  What is the issue you're having and what leads you to those transistors as being the cause?
« Last Edit: April 18, 2024, 02:10:51 am by bdunham7 »
  • Country: cn
« Reply #13 on: April 18, 2024, 02:54:34 am »
My FLUKE 8920a encountered a strange failure, please watch the video---
This is what I posted a few days ago, but no one can help me :palm:--https://www.eevblog.com/forum/repair/fluke-8920a-multimeter-repair-needs-some-help/
If 8920a is not powered on for a long time (power on),The first time you turn it on, it will definitely have the above fault.
If it is normal, turn on the 8920a every day and it will return to normal.So I spent a lot of time testing it,I've never been able to pinpoint the fault point
The fault phenomenon is that when you turn on the computer, you will see "700" flashing all the time.
Sometimes the "mv" gear and "V" gear keep jumping automatically, just like what was captured in the video
I don't know how to find the fault point correctly
« Last Edit: April 18, 2024, 03:04:08 am by daisizhou »
  • Country: cn
« Reply #14 on: April 18, 2024, 09:09:33 am »
This is the latest video. It seems that the fault is related to the gear, especially the low range enable.
  • Country: cn
« Reply #15 on: April 19, 2024, 02:48:27 am »
Q209 and Q208 seem to be like this, but my fault still exists.
