Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
What is this component
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: What is this component (Read 832 times)
kamalshah
Newbie
Country:
on:
July 24, 2021, 05:49:57 pm »
I had bought a this Car cooling fan and it worked fine but later one of the fans stopped working. I took it apart and checked everything I could. and it all seamed to work fine.
https://www.aliexpress.com/item/4001118023418.html?spm=a2g0s.9042311.0.0.6f6f4c4ddcUwDp
but the fan would still not work even though the other fan works fine plugged in to this fans wire. So I thought the component in the picture might be the problem. I googled the part number but found nothing. It has 4 prongs and looks like a transistor. it has the following written on it: "0CS 29830 0QAG"
Logged
Manul
Super Contributor
Country:
Re: What is this component
Reply #1 on:
July 24, 2021, 05:56:12 pm »
It is likely OCH29830. It is a hall sensor with some integrated motor driver.
Logged
kamalshah
fzabkar
Super Contributor
Country:
Reply #2 on:
July 24, 2021, 06:05:02 pm »
I suspect that it is a Hall Effect sensor.
OCS = Shanghai Orient-Chip Technology Co.,LTD
http://www.orient-chip.com/Pages/ProductList.aspx?cl=en&ClassId=25&SecondId=69&Type=1&Parameter=&ReId=&ReNew=&key=
http://www.orient-chip.com/Pages/ProductDetail.aspx?cl=en&id=1823
(OCH29830)
http://www.orient-chip.com/Upload/File/2020-02-18/202002181350493678.pdf
(OCH29830)
http://www.orient-chip.com/Upload/File/2020-02-18/202002181354395734.pdf
(OCH29831)
Last Edit: July 24, 2021, 08:27:42 pm by fzabkar
Logged
kamalshah
kamalshah
Newbie
Country:
Reply #3 on:
July 24, 2021, 06:50:08 pm »
Thanks I could never have guessed it.
when I turn it on the motor drives for a couple of revolutions and then stops working.
I have a multimeter, Can I test it with that?
plus how can I order one to repair it.
Thanks again
Logged
kamalshah
Newbie
Country:
Reply #4 on:
July 24, 2021, 07:25:49 pm »
This is the circuit behind the coil,
Logged
kamalshah
Newbie
Country:
Reply #5 on:
July 24, 2021, 07:26:39 pm »
The fan coil
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
