VR typically refers to a variable resistor (or varistor). 2 leads usually indicates a rheostat, but in this case, I think a MOV (metal oxide varistor) is the actual part being used. They're more commonly a disk shape with parallel leads, they may have located an axial version to fit the enclosure.
And given the photo of the second photo, I'd say it's a gas discharge tube.
