Author Topic: What is this diode ? (Please help me)  (Read 652 times)
Offline thitouTopic starter
« on: December 14, 2024, 07:42:42 pm »
Hello everyone, I'm repairing an acer x330 led projector.
The red led no longer lights up, due to a defective diode. If you look at the picture attached, it's the one with 3115 marked on it.
Is there a technique to read the codes of the diodes?
I tried to find a replacement, but by typing this reference on the internet I get this:
https://eu.mouser.com/ProductDetail/Nexperia/PESD5Z3.3115?qs=LOCUfHb8d9vJaxAfWbkFOQ%3D%3D
Does this seem correct to you?
The red led seems to work with 5 volts (max), if this can help.
Thank you a lot  :-+  :-+
« Last Edit: December 14, 2024, 07:56:57 pm by thitou »
Online fzabkar
Re: What is this diode ? (Please help me)
« Reply #1 on: December 14, 2024, 09:41:53 pm »
It looks like the freewheeling diode in a stepdown DC-DC converter. Therefore, your proposed replacement is unsuitable. Instead, it would be a fast Schottky rectifier diode.
Can you identify the stepdown DC-DC converter IC? The application diagram might provide confirmation.
Otherwise, look here:
http://markingcodes.com/search/c/31
The "15" on the second line could be a date or batch code.
Here is a possible candidate:
https://nz.rs-online.com/web/p/schottky-diodes-rectifiers/2636897
https://docs.rs-online.com/4293/0900766b8101fb39.pdf (datasheet for RB051L-40)
« Last Edit: December 14, 2024, 09:45:11 pm by fzabkar »
« Reply #2 on: December 14, 2024, 10:12:34 pm »
Indeed, I suspected that the diode I had found was not the right one. But I didn't know how to read this code "31 15" with your indications it's a little clearer, thank you very much!
Thanks for your research, I'll see tomorrow for the DC DC converter. I'll send you a message right away.
Your link for the marking codes database very helpful!!
« Reply #3 on: December 15, 2024, 12:06:15 pm »
Hello,
Here is a picture of the ic. Unfortunately I couldn't find the datasheet.
The reference is 1D (or 10) 3749 N5754
Thanks!  :-+
Online fzabkar
« Reply #4 on: December 15, 2024, 05:36:54 pm »
LT3743
https://www.analog.com/media/en/technical-documentation/data-sheets/3743fe.pdf
CBOOT (Pin 25/Pin 26):
The CBOOT pin provides a floating 5V regulated supply for the high side FET driver. An external Schottky diode is required from the VCC_INT pin to the CBOOT pin to charge the CBOOT capacitor when the switch pin is near ground.
« Last Edit: December 15, 2024, 05:40:52 pm by fzabkar »
« Reply #5 on: December 16, 2024, 11:19:58 am »
Thank you for the datasheet !
