Author Topic: what is this ic  (Read 1415 times)
Offline esiniorTopic starter
what is this ic
« on: August 26, 2021, 06:30:53 pm »
hi, i have a 220v motor driver and i think it is a dimmer from its bt138 triac (it goes to a 220-24 trans and then to the motor) and its ic surface is erased and expunged and i don't know its number, does anyone know what this could be?
« Last Edit: August 26, 2021, 06:34:14 pm by esinior »
Offline jpanhalt
Re: what is this ic
« Reply #1 on: August 26, 2021, 06:59:31 pm »
That looks like it may be a Chip on board (COB) : https://en.wikipedia.org/wiki/Chip_on_board  Identification marks were not erased.  They were never there.
Your guess is as good as ours.
Edit:  Oops  :-[
« Last Edit: August 27, 2021, 06:04:37 am by jpanhalt »
The following users thanked this post: esinior
Offline fzabkar
Re: what is this ic
« Reply #2 on: August 27, 2021, 01:11:15 am »
Are you mistaking the knob on the pot for an IC blob?
The following users thanked this post: jpanhalt, esinior
Offline BrokenYugo
Re: what is this ic
« Reply #3 on: August 27, 2021, 01:18:31 am »
Pretty sure the question is about the DIP 16 package with the markings sanded off.
Offline DrG
Re: what is this ic
« Reply #4 on: August 27, 2021, 02:01:52 am »
Agreed. I don't know what it is. The only think I could suggest is that the OP draws out the circuit as everything else is identifiable. Given that you have a decent idea of what it does, someone could certainly speculate what IC would make sense there. Not terribly helpful, I know.
- Invest in science - it pays big dividends. -
Re: what is this ic
« Reply #5 on: August 27, 2021, 05:18:06 pm »
no,it is cleared and sanded
Re: what is this ic
« Reply #6 on: August 27, 2021, 05:22:22 pm »
ooooo :palm: i didn't notice it, i didn't say that , ic is that 16-pin DIP one
Re: what is this ic
« Reply #7 on: August 27, 2021, 05:23:49 pm »
yes, the question is about that
Re: what is this ic
« Reply #8 on: August 27, 2021, 05:28:29 pm »
it is a dimmer i think, doesn't anyone have an dimmer design with an ic?
Online amyk
Re: what is this ic
« Reply #9 on: August 27, 2021, 07:32:01 pm »
U2010B ? Seems to match the circuit at first glance.
The following users thanked this post: fzabkar, esinior
Re: what is this ic
« Reply #10 on: April 23, 2022, 08:31:48 am »
thanks, i'll check that
Online inse
Re: what is this ic
« Reply #11 on: April 23, 2022, 02:48:49 pm »
If it was a dimmer - wow!
Not a single piece of filtering or protection around the TRIAC.
