Author Topic: what is this part?  (Read 1084 times)
Offline vixoTopic starter
what is this part?
« on: October 05, 2023, 02:38:33 pm »
I think this part says BD4 5C14 but I can't find in any database a reference for this part code, does anyone know? Help much appreciated!
Offline Zenith
Re: what is this part?
« Reply #1 on: October 05, 2023, 03:15:22 pm »
Which equipment is a part of? That may help shed some light on it. Can you get the manual for the equipment?
Looking at the picture it appears to be designated D4, which suggests it's a package of diodes.
Offline Daixiwen
  • Country: no
« Reply #2 on: October 17, 2023, 06:53:13 am »
Doesn't D4 apply to the diode in the bottom left hand corner? The reference designators on that silkscreen are a bit all over the place
Online Psi
« Reply #3 on: October 17, 2023, 07:26:45 am »
Logo might be Torex Semiconductors
Offline mengfei
  • Country: ph
« Reply #4 on: October 17, 2023, 07:53:05 am »
might help
good ol Picasa 3 functions
Online Psi
« Reply #5 on: October 17, 2023, 07:55:56 am »
Definitely looks like Torex Semiconductors, you can now see the curve of the line
Pretty sure the package style is called MSOP-10 by Torex
« Last Edit: October 17, 2023, 08:02:30 am by Psi »
Offline mengfei
  • Country: ph
« Reply #6 on: October 17, 2023, 08:00:38 am »
which country is Torex originally from?
Heard before but never came across some of our projects
Online Psi
« Reply #7 on: October 17, 2023, 08:12:16 am »
If you go here and then click "Products using this package" you find some things that could be it
https://product.torexsemi.com/en/packages/msop-10
Ground is on pin9, which is correct.  But i cant match up any of the part numbers to the part numbers on the chip.
Its possible its an older obsolete/previous version of these IC's
Check what pins that inductor to the right is across, and match them up to the datasheets.
« Last Edit: October 17, 2023, 08:14:37 am by Psi »
Offline janoc
« Reply #8 on: October 17, 2023, 12:19:11 pm »
That pin 4 soldering looks a bit dodgy. If that IC is causing problems touch the soldering up.
Online wasedadoc
« Reply #9 on: October 17, 2023, 05:08:07 pm »
Looks more like 3B4 to me.
Offline fzabkar
« Reply #10 on: October 17, 2023, 06:52:30 pm »
I'm not sure about this one ...
https://product.torexsemi.com/system/files/series/xc9502.pdf
It's a different IC, but the marking codes for the XC9128/XC9129 might provide clues. For example, it appears that the feedback voltage is 0.45V.
https://product.torexsemi.com/files/status/xc9128.pdf
Edit: Could "3B4" be "8B4", in which case the IC could be XC9128B45CAR?
http://markingcodes.com/search/c/8b4
8B4+5CXX --> XC9128B45CAR
« Last Edit: October 18, 2023, 03:02:12 am by fzabkar »
The following users thanked this post: mengfei
