Author Topic: What is this resistor?  (Read 1299 times)
Offline wadmancpuTopic starter
« on: November 13, 2019, 07:46:15 pm »
Am I crazy or isn't this a 2,000 ohm resistor? Also isn't this ceramic? I can't seem to find these either. Thanks all.
Offline schmitt trigger
  • Country: mx
Re: What is this resistor?
« Reply #1 on: November 13, 2019, 08:11:49 pm »
This looks very similar to fusible resistors found as in-rush limiters in high power supplies.
Low power supplies can use a thermistor as an inrush limiter, but even at its lowered resistance can create high losses.
Therefore a high power supply usually employs a fixed resistor that is fully shorted out by a relay after a set time.
However...if for whatever reason the relay contact's do not close, the resistor will become cherry-hot and could actually cause a fire.
Thus, these types of resistors have a thermal cutout which will permanently open if the resistor's maximum temperature is exceeded.
Having said this, for a more accurate answer, would you kindly tell us the circuit you remove this resistor from?
« Last Edit: November 13, 2019, 08:13:21 pm by schmitt trigger »
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #2 on: November 13, 2019, 08:19:42 pm »
wirewound R2 = 0.2ohm,  K=10% tolerance.
Salvaged from an audio amp, guessing.
Offline Yansi
« Reply #3 on: November 13, 2019, 08:25:33 pm »
Resistors with thermal cutout look different.¨Thermal cutout would be explicitly stated on it. I think this one is a bog standard wirewound 0.2ohm one. Fusible resistors are also very different kind.
This is how resistor with thermal cutout looks like:
« Reply #4 on: November 13, 2019, 08:30:04 pm »
This out of a tv power supply. Thank you for the specs on this. It was testing shorted and I thought 2k would be 2,000 ohms. I see now .2 ohms why it tests the way it does. Does anyone have a link that shows what these numbers and letters indicate?
Offline Yansi
« Reply #5 on: November 13, 2019, 08:32:37 pm »
R is the standard character for OHM, while K is standard identificator for 10% tolerance.
These letters are also used extensively on other passives such as foil capacitors.  J, K and M being the most often seen.
//EDIT: More on the markings here: http://www.iequalscdvdt.com/Markings_and_Codes.html
//EDIT2: On my photo of resistors with thermal cutout, you can see the letter J used to identify +-5% tolerance of those 10 ohms.
« Last Edit: November 13, 2019, 08:36:17 pm by Yansi »
« Reply #6 on: November 13, 2019, 10:59:04 pm »
Excellent, thank you!
  • Country: mx
« Reply #7 on: November 14, 2019, 04:09:54 am »
Thanks for the clarification.
