Hi!
At home we have an older Bosch dishwasher (SGV59A23/22) that suddenly stopped working mid cycle. The symptoms are... it's dead
. Pressing the power switch does nothing, the little LED display is dead, the program select buttons do nothing, ... Now I have traced the input voltage and that seems to be going in the right places. So the obvious culprit seems to be the actual controller board. This gets the mains voltage input (it does get there) and then has what I think is a simple switcher PSU on there that supplies the control circuitry.
When I first got the board in my hands I immediately noticed a cracked solder joint on one of the relays and a few more that look slightly dull. I re-flowed the most suspicious looking ones and tried the board again... no change.
So I took the board out again and started looking into it a bit more. There is a ST 78m05a voltage regulator (5V output) on there and it seems to be relatively near the PSU, so I assume that this is the main regulator. I tried applying around 8V to the input, just enough for it to start regulating - and it did. I was getting 5V on the output and the board was drawing around 500mA. That's when I noticed that the main MCU (mc68hc908ab32) was getting extremely hot - in just a few seconds really.
That's when I unplugged it and started doing some basic continuity checks and noticed that the regulator output and GND seem to be nearly shorted. There is about 16 ohms of resistance between those. Not sure if that is to be expected or not. Seeing how I was getting 5V on the output I am assuming that this is not an issue. What I am assuming is an issue is the MCU getting really hot. Could be that there is a short somewhere in the main MCU, or is it more likely that the short is somewhere external and that is causing the MCU to get hot? Do I even check around, or just assume that the MCU is dead?
Here are two pictures of the controller board. Sadly I cannot seem to find any schematics or anything, and I cannot find any replacements either.
